주요 콘텐츠로 건너뛰기
HP LaserJet 1160 or 1320 Duplexer PCB Replacement
필요한 것
  1. HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Left Side Cover: 1 단계, 이미지 1/3 HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Left Side Cover: 1 단계, 이미지 2/3 HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Left Side Cover: 1 단계, 이미지 3/3
    • Pull on the two tabs on the back of the printer to release the left side cover.
    • Remove the cover by rotating it towards the front of the printer.
  2. HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Right Side Cover: 2 단계, 이미지 1/3 HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Right Side Cover: 2 단계, 이미지 2/3 HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Right Side Cover: 2 단계, 이미지 3/3
    • With the printer turned so that the right side is facing upwards, use a metal spudger to disengage 3 tabs holding the right side cover in place.
    • Lift the cover off of the printer.
  3. HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Back Cover: 3 단계, 이미지 1/3 HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Back Cover: 3 단계, 이미지 2/3 HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Back Cover: 3 단계, 이미지 3/3
    • Remove 4 screws on the back of the printer.
    • Remove the back cover.
  4. HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Top Cover: 4 단계, 이미지 1/3 HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Top Cover: 4 단계, 이미지 2/3 HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Top Cover: 4 단계, 이미지 3/3
    • Remove 2 screws on the back of the printer, one on the left, and one on the front.
    • The second image shows the formatter removed, but it is not necessary to remove the formatter to replace the top cover.
  5. HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Top Cover: 5 단계, 이미지 1/1
    • Disconnect the control panel cable and remove the top cover.
  6. HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Fan: 6 단계, 이미지 1/2 HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Fan: 6 단계, 이미지 2/2
    • Disconnect the fan cable from the main board of the printer.
    • Remove the retaining clip holding the fan in.
    • Remove the 2 screws holding the fan in.
  7. HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Fan Cable: 7 단계, 이미지 1/3 HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Fan Cable: 7 단계, 이미지 2/3 HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Fan Cable: 7 단계, 이미지 3/3
    • Remove the fan cable from the cable guide.
  8. HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Duplexer PCB: 8 단계, 이미지 1/2 HP LaserJet 1160 or 1320 Duplexer PCB Replacement, Duplexer PCB: 8 단계, 이미지 2/2
    • Disconnect one cable from the main board of the printer.
    • Disconnect the duplexer solenoid cable from the duplexer PCB.
    • Remove one screw on the duplexer PCB and remove the PCB from the printer.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
jdp23
회원 가입일: 08/22/13
1,302 평판
안내서 23개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 12
전체 시간: 396
