주요 콘텐츠로 건너뛰기
HP LaserJet 1160 or 1320 Formatter Replacement
필요한 것
  1. HP LaserJet 1160 or 1320 Formatter Replacement, Left Side Cover: 1 단계, 이미지 1/3 HP LaserJet 1160 or 1320 Formatter Replacement, Left Side Cover: 1 단계, 이미지 2/3 HP LaserJet 1160 or 1320 Formatter Replacement, Left Side Cover: 1 단계, 이미지 3/3
    • Pull on the two tabs on the back of the printer to release the left side cover.
    • Remove the cover by rotating it towards the front of the printer.
  2. HP LaserJet 1160 or 1320 Formatter Replacement, Formatter: 2 단계, 이미지 1/3 HP LaserJet 1160 or 1320 Formatter Replacement, Formatter: 2 단계, 이미지 2/3 HP LaserJet 1160 or 1320 Formatter Replacement, Formatter: 2 단계, 이미지 3/3
    • Remove 2 screws on the I/O port cover.
    • Remove 6 screws on the formatter.
    • Disconnect 3 connectors from the formatter.
    • Disconnect 2 flat flexible cables from the formatter.
    • Remove the formatter from the printer.
    • Be careful not to fold, crease, or tear flat flexible cables.
    • The I/O port cover will need to be transferred to the new formatter before installing it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
jdp23
회원 가입일: 08/22/13
1,302 평판
안내서 23개 작성하였습니다
댓글 한 개
Additional connector attached to bottom left of board ignored
R F Rossiter - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 1,188
