주요 콘텐츠로 건너뛰기
HP LaserJet P1102w Left Side Panel Replacement
필요한 것
  1. HP LaserJet P1102w Left Side Panel Replacement, Left Side Panel: 1 단계, 이미지 1/3 HP LaserJet P1102w Left Side Panel Replacement, Left Side Panel: 1 단계, 이미지 2/3 HP LaserJet P1102w Left Side Panel Replacement, Left Side Panel: 1 단계, 이미지 3/3
    • Flip printer on it's back. Using the plastic spudger, pry off front panel. There will be two main points to focus as shown.
    • Pry carefully to not break any plastic.
  2. HP LaserJet P1102w Left Side Panel Replacement: 2 단계, 이미지 1/2 HP LaserJet P1102w Left Side Panel Replacement: 2 단계, 이미지 2/2
    • Now that the pry points are free lift up the front panel.
  3. HP LaserJet P1102w Left Side Panel Replacement: 3 단계, 이미지 1/2 HP LaserJet P1102w Left Side Panel Replacement: 3 단계, 이미지 2/2
    • Unscrew the #1 Phillips screw 6mm on the back of the printer.
  4. HP LaserJet P1102w Left Side Panel Replacement: 4 단계, 이미지 1/3 HP LaserJet P1102w Left Side Panel Replacement: 4 단계, 이미지 2/3 HP LaserJet P1102w Left Side Panel Replacement: 4 단계, 이미지 3/3
    • Using the plastic spudger, remove the button housing from the top left of printer.
  5. HP LaserJet P1102w Left Side Panel Replacement: 5 단계, 이미지 1/2 HP LaserJet P1102w Left Side Panel Replacement: 5 단계, 이미지 2/2
    • Once the housing is removed, remove the three buttons.
  6. HP LaserJet P1102w Left Side Panel Replacement: 6 단계, 이미지 1/3 HP LaserJet P1102w Left Side Panel Replacement: 6 단계, 이미지 2/3 HP LaserJet P1102w Left Side Panel Replacement: 6 단계, 이미지 3/3
    • Use the plastic spudger to remove the side panel. There are three main prying points as shown.
  7. HP LaserJet P1102w Left Side Panel Replacement: 7 단계, 이미지 1/2 HP LaserJet P1102w Left Side Panel Replacement: 7 단계, 이미지 2/2
    • With all pry points free, remove the side panel.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jerome Etten
회원 가입일: 10/04/18
709 평판
안내서 4개 작성하였습니다
UW Stout, Team S6-G4, Ogden Fall 2018 UW Stout, Team S6-G4, Ogden Fall 2018 회원
UWSTOUT-OGDEN-F18S6G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 7
30일 전: 32
전체 시간: 1,474
