주요 콘텐츠로 건너뛰기
HP Laserjet Pro 200 Color MFP Toner Cartridge Drawer Replacement
필요한 것
  1. HP Laserjet Pro 200 Color MFP  Toner Cartridge Drawer Replacement, Toner Cartridge Drawer: 1 단계, 이미지 1/1
    • Open the front cover by grasping the edge and pulling it outwards.
  2. HP Laserjet Pro 200 Color MFP  Toner Cartridge Drawer Replacement: 2 단계, 이미지 1/1
    • Pull out the toner cartridge drawer by using the handle as shown.
  3. HP Laserjet Pro 200 Color MFP  Toner Cartridge Drawer Replacement: 3 단계, 이미지 1/1
    • Use the handles built into the toner cartridges to remove them by pulling straight upwards.
    • Remove all 4 toner cartridges.
    • Each toner cartridge has a specific place depending on color. The right locations for each cartridge can be found by looking at the colored stickers on the right side of the drawer. This is important to note for reassembly.
  4. HP Laserjet Pro 200 Color MFP  Toner Cartridge Drawer Replacement: 4 단계, 이미지 1/2 HP Laserjet Pro 200 Color MFP  Toner Cartridge Drawer Replacement: 4 단계, 이미지 2/2
    • There are 2 locks on the inner walls of the sides of the printer which need to be removed in order to have access to the toner drawer.
    • Use the opening tool or a small flathead screwdriver to depress the small button on the inside of the lock. This button keeps the lock from moving.
    • The second picture shows what these lock assemblies look like.
  5. HP Laserjet Pro 200 Color MFP  Toner Cartridge Drawer Replacement: 5 단계, 이미지 1/3 HP Laserjet Pro 200 Color MFP  Toner Cartridge Drawer Replacement: 5 단계, 이미지 2/3 HP Laserjet Pro 200 Color MFP  Toner Cartridge Drawer Replacement: 5 단계, 이미지 3/3
    • While continuing to depress the button, use your finger to grab ahold of the lock.
    • Push it forwards into the printer and maintain pressure on the lock.
    • Pivot the back end of the lock away from the inner wall of the printer and towards you until it pops out.
  6. HP Laserjet Pro 200 Color MFP  Toner Cartridge Drawer Replacement: 6 단계, 이미지 1/1
    • Repeat steps 4 and 5 for the lock on the opposite side of the printer.
  7. HP Laserjet Pro 200 Color MFP  Toner Cartridge Drawer Replacement: 7 단계, 이미지 1/1
    • Pull out the faulty ink cartridge drawer and replace it with a functioning drawer.
결론
To reassemble your device, follow the instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Kendall Gentzen
회원 가입일: 04/18/19
981 평판
안내서 5개 작성하였습니다
Cal Poly, Team S9-G14, Maness Spring 2019 Cal Poly, Team S9-G14, Maness Spring 2019 회원
CPSU-MANESS-S19S9G14
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 18
30일 전: 72
전체 시간: 4,381
