소개
Is your HP Laserjet Pro 200 not connecting to wifi? If so, then there may be an issue with the wifi card. This guide demonstrates how to quickly replace the wifi card inside your printer. All you need is a Phillips #2 Screwdriver and iFixit Opening Tool!
필요한 것
Turn the printer so that the front is facing to your left.
Flip the printer so that it is laying with its left side facing down and the bottom facing you.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 한 개
It’s worth to notice, that putting it all back together is not that simple as it sounds, at least in my case it wasn’t. The front part of the panel has to go in first. Pay extra attention if the vertical edge on the front panel is aligned with the rest of the printer. If it isn’t, it won’t snap in afterwards, so you have to ensure that first. At least I had to.
The negative aspect of that approach is that it will take extra force to put the back part (with the tabs you were depressing) in. I had to help myself with WD-40 as the plastic wouldn’t bend far enough to loosely go into the place.
Also, the turn-on button can not be pressed in when putting it all together as it will block itself on the power switch internal case. Forcing it in will only cause the button to break.
