주요 콘텐츠로 건너뛰기
HP Laserjet Pro 200 Color MFP Fan Replacement
필요한 것
  1. HP Laserjet Pro 200 Color MFP Fan Replacement, Fan: 1 단계, 이미지 1/2 HP Laserjet Pro 200 Color MFP Fan Replacement, Fan: 1 단계, 이미지 2/2
    • Turn the printer so that the front is facing to your left.
    • Flip the printer so that it is laying with its right side facing down and the bottom facing you.
  2. HP Laserjet Pro 200 Color MFP Fan Replacement: 2 단계, 이미지 1/1
    • Remove the 8 mm screw on the top edge of the printer using a #2 Phillips head screwdriver.
  3. HP Laserjet Pro 200 Color MFP Fan Replacement: 3 단계, 이미지 1/3 HP Laserjet Pro 200 Color MFP Fan Replacement: 3 단계, 이미지 2/3 HP Laserjet Pro 200 Color MFP Fan Replacement: 3 단계, 이미지 3/3
    • There are three tabs along the back right corner of the printer underneath the panel shown (location is displayed in second picture).
    • Use a flathead screwdriver to depress these tabs while lightly pulling the panel towards you.
    • Begin with the upmost tab and move your way down, individually depressing the tabs while simultaneously pulling the panel towards you, removing it from the printer.
  4. HP Laserjet Pro 200 Color MFP Fan Replacement: 4 단계, 이미지 1/1
    • Rotate the printer so you are facing the open side.
  5. HP Laserjet Pro 200 Color MFP Fan Replacement: 5 단계, 이미지 1/1
    • Gently pull out the plug that supplies power to the fan from the socket on the circuit board.
    • Be careful when removing the plug as the components are fragile.
  6. HP Laserjet Pro 200 Color MFP Fan Replacement: 6 단계, 이미지 1/3 HP Laserjet Pro 200 Color MFP Fan Replacement: 6 단계, 이미지 2/3 HP Laserjet Pro 200 Color MFP Fan Replacement: 6 단계, 이미지 3/3
    • There are three tabs that hold the fan in place, as shown in the first picture. These steps may require an extra pair of hands in order to depress all the tabs.
    • Push each tab outwards from the fan.
    • Simultaneously pull the fan towards you until the fan clears the face of the printer.
결론
To reassemble your device, follow the instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Kendall Gentzen
회원 가입일: 04/18/19
981 평판
안내서 5개 작성하였습니다
Cal Poly, Team S9-G14, Maness Spring 2019 Cal Poly, Team S9-G14, Maness Spring 2019 회원
CPSU-MANESS-S19S9G14
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 10
30일 전: 27
전체 시간: 1,094
