주요 콘텐츠로 건너뛰기
HP Laserjet Pro 200 Color MFP Power Button Replacement
필요한 것
  1. HP Laserjet Pro 200 Color MFP Power Button Replacement, Power Button: 1 단계, 이미지 1/2 HP Laserjet Pro 200 Color MFP Power Button Replacement, Power Button: 1 단계, 이미지 2/2
    • Turn the printer so that the front is facing to your left.
    • Flip the printer so that it is laying with its left side facing down and the bottom facing you.
  2. HP Laserjet Pro 200 Color MFP Power Button Replacement: 2 단계, 이미지 1/1
    • Use a #2 Phillips head screwdriver to unscrew the 8mm screw on the top edge of the printer.
  3. HP Laserjet Pro 200 Color MFP Power Button Replacement: 3 단계, 이미지 1/3 HP Laserjet Pro 200 Color MFP Power Button Replacement: 3 단계, 이미지 2/3 HP Laserjet Pro 200 Color MFP Power Button Replacement: 3 단계, 이미지 3/3
    • There are three tabs along the back right corner of the printer underneath the panel (location is displayed in the second picture).
    • Use a flathead screwdriver to depress the tabs while lightly pulling the panel towards you.
    • Begin with the upmost tab and move your way down, individually depressing the tabs.
    • Pull the panel towards you and remove it from the printer.
  4. HP Laserjet Pro 200 Color MFP Power Button Replacement: 4 단계, 이미지 1/2 HP Laserjet Pro 200 Color MFP Power Button Replacement: 4 단계, 이미지 2/2
    • Turn the printer so that you are facing the open side with the power button chord.
    • Carefully remove this cord.
  5. HP Laserjet Pro 200 Color MFP Power Button Replacement: 5 단계, 이미지 1/3 HP Laserjet Pro 200 Color MFP Power Button Replacement: 5 단계, 이미지 2/3 HP Laserjet Pro 200 Color MFP Power Button Replacement: 5 단계, 이미지 3/3
    • There is a cover that protects the electronics within the power button.
    • Remove it by pinching the two tabs on the cover.
    • Pull it outward from the printer.
  6. HP Laserjet Pro 200 Color MFP Power Button Replacement: 6 단계, 이미지 1/1
    • A tension spring in the form of a bent wire is used to hold the assembly in the printer.
    • In order to remove the spring completely, begin by removing the right end of the wire from it's slot above the power button with a metal spudger.
  7. HP Laserjet Pro 200 Color MFP Power Button Replacement: 7 단계, 이미지 1/1
    • Unclip the left side of the wire from printer by applying upwards pressure along the edge of the wire.
    • This step can be done with either your fingers or a prying tool of your choosing.
  8. HP Laserjet Pro 200 Color MFP Power Button Replacement: 8 단계, 이미지 1/3 HP Laserjet Pro 200 Color MFP Power Button Replacement: 8 단계, 이미지 2/3 HP Laserjet Pro 200 Color MFP Power Button Replacement: 8 단계, 이미지 3/3
    • Grab the wire and hold it firmly with two fingers.
    • Pull it directly upwards.
    • Wiggle it until it is fully removed from the printer.
  9. HP Laserjet Pro 200 Color MFP Power Button Replacement: 9 단계, 이미지 1/1
    • Pull the power button board directly towards you, until both the board and the wire are fully clear of the printer.
결론
To reassemble your device, follow the instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Kendall Gentzen
회원 가입일: 04/18/19
981 평판
안내서 5개 작성하였습니다
Cal Poly, Team S9-G14, Maness Spring 2019 Cal Poly, Team S9-G14, Maness Spring 2019 회원
CPSU-MANESS-S19S9G14
4 회원들
안내서 11개 작성하였습니다
댓글 한 개
super tuto
avez vous un tuto similaire pour le remplacement de la carte d'alimentation grillée par la foudre ?
philippe juge - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 12
30일 전: 32
전체 시간: 1,922
