소개
Is your HP Laserjet Pro 200 not turning on? Then there may be an issue with the power button. This guide demonstrates how to quickly replace the power button inside your printer. All you need is a Phillips #2 Screwdriver, iFixit Opening Tool, and Metal Spudger!
필요한 것
Turn the printer so that the front is facing to your left.
Flip the printer so that it is laying with its left side facing down and the bottom facing you.
To reassemble your device, follow the instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
super tuto
avez vous un tuto similaire pour le remplacement de la carte d'alimentation grillée par la foudre ?
