주요 콘텐츠로 건너뛰기
HP Laserjet Pro 200 Color MFP Printer Roller Replacement
필요한 것
  1. HP Laserjet Pro 200 Color MFP Printer Roller Replacement, Printer Roller: 1 단계, 이미지 1/1
    • Plug in the printer to a wall outlet and place the printer on an accessible surface.
  2. HP Laserjet Pro 200 Color MFP Printer Roller Replacement: 2 단계, 이미지 1/2 HP Laserjet Pro 200 Color MFP Printer Roller Replacement: 2 단계, 이미지 2/2
    • In order to rotate the roller to the maintenance position, a secondary menu must be unlocked via the display.
    • To unlock this menu, click on Settings tab (the wrench icon in the top left corner).
    • Once in the Settings menu , quickly click and hold the mid left side of the display (orange square).
    • While continuing to hold the left side, click the bottom right corner of the display (yellow square) and hold it. This should you bring you right back to the startup menu.
    • Once again, click on the Settings tab.
  3. HP Laserjet Pro 200 Color MFP Printer Roller Replacement: 3 단계, 이미지 1/2 HP Laserjet Pro 200 Color MFP Printer Roller Replacement: 3 단계, 이미지 2/2
    • Once in the Service menu, click on the "2ndary Service" tab.
    • Scroll down by pressing the down arrow on the bottom right corner of the screen until you find the tab labeled "Pick Roller."
    • Select "Pick Roller."
  4. HP Laserjet Pro 200 Color MFP Printer Roller Replacement: 4 단계, 이미지 1/1
    • Press the "OK" button on the bottom right corner of the screen.
  5. HP Laserjet Pro 200 Color MFP Printer Roller Replacement: 5 단계, 이미지 1/1
    • Unplug the printer from the side by pulling on the base of the cord.
    • Unplug the printer rather than manually turning it off using the power button in order for the roller to stay in maintenance position.
  6. HP Laserjet Pro 200 Color MFP Printer Roller Replacement: 6 단계, 이미지 1/1
    • Remove the paper tray by pulling it out from the bottom completely.
  7. HP Laserjet Pro 200 Color MFP Printer Roller Replacement: 7 단계, 이미지 1/2 HP Laserjet Pro 200 Color MFP Printer Roller Replacement: 7 단계, 이미지 2/2
    • Rotate the printer as shown so that the front is facing your left.
    • Flip the printer so that its right side is facing down, and you are facing the bottom.
  8. HP Laserjet Pro 200 Color MFP Printer Roller Replacement: 8 단계, 이미지 1/1
    • Use a metal spudger or a small flathead screwdriver to lift the tabs on each side of the roller.
  9. HP Laserjet Pro 200 Color MFP Printer Roller Replacement: 9 단계, 이미지 1/2 HP Laserjet Pro 200 Color MFP Printer Roller Replacement: 9 단계, 이미지 2/2
    • Pull out and remove the roller.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kendall Gentzen
회원 가입일: 04/18/19
981 평판
안내서 5개 작성하였습니다
Cal Poly, Team S9-G14, Maness Spring 2019 Cal Poly, Team S9-G14, Maness Spring 2019 회원
CPSU-MANESS-S19S9G14
4 회원들
안내서 11개 작성하였습니다
댓글 5개
Simple and exact.
Jjay - 답글
I can not get the 2ndary Service menu to appear. I have followed these instructions very carefully. Is there another way to access this mennu?
James Herzog - 답글
@James Herzog. I had to try at least ten times before I got that key sequence working. Try pushing bit different spots and bit different speeds etc.
Rixa - 답글
Lord God. This worked just as you instructed. I'm still ready to throw the printer to the curb, but this did work!!
Karen-Glenn Richardson - 답글
Thank you so much, I reversed the rubber band in the roller and now it worked like new
Ali AlKhawaher - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 25
30일 전: 126
전체 시간: 9,024
