소개
The internal cooling fan is responsible for maintaining optimal operational conditions for the HP Media Center 876x processor. If your computer will not turn on, or will turn off randomly, then the internal fan may require replacement.
필요한 것
Apply great pressure with fingers on the tabs of the fan casing.
While applying pressure, pull the casing upwards to remove.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
