주요 콘텐츠로 건너뛰기
HP Media Center 876x Optical Drive Replacement
필요한 것
  1. HP Media Center 876x Optical Drive Replacement, Side Panel: 1 단계, 이미지 2개 중 1개 HP Media Center 876x Optical Drive Replacement, Side Panel: 1 단계, 이미지 2개 중 2개
    • Remove the two (9 mm) hand screws on the back panel.
  2. HP Media Center 876x Optical Drive Replacement: 2 단계, 이미지 3개 중 1개 HP Media Center 876x Optical Drive Replacement: 2 단계, 이미지 3개 중 2개 HP Media Center 876x Optical Drive Replacement: 2 단계, 이미지 3개 중 3개
    • Place the tower on its side.
    • Slide the side panel horizontally to detach, and pull upward to remove.
  3. HP Media Center 876x Optical Drive Replacement, Front Cover: 3 단계, 이미지 2개 중 1개 HP Media Center 876x Optical Drive Replacement, Front Cover: 3 단계, 이미지 2개 중 2개
    • Orient the tower vertically.
    • Using the #0 Phillips head screwdriver, unscrew and remove the two (5 mm) screws that fasten the remaining side panel to the tower.
    • Slide the side panel out of its notches, and pull it gently off of the tower.
  4. HP Media Center 876x Optical Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Gently move the tower so that it is in the horizontal orientation.
    • Press down the black tabs (proximal to you) that fasten the front panel to the tower.
    • Press down on the distal, black tabs (symmetric with respect to the previous tabs).
    • Pull front panel forward slightly.
  5. HP Media Center 876x Optical Drive Replacement: 5 단계, 이미지 2개 중 1개 HP Media Center 876x Optical Drive Replacement: 5 단계, 이미지 2개 중 2개
    • The front panel will come off in a hinge-like fashion, exposing the drives underneath.
  6. HP Media Center 876x Optical Drive Replacement, Optical Drive: 6 단계, 이미지 3개 중 1개 HP Media Center 876x Optical Drive Replacement, Optical Drive: 6 단계, 이미지 3개 중 2개 HP Media Center 876x Optical Drive Replacement, Optical Drive: 6 단계, 이미지 3개 중 3개
    • Identify the optical drive.
    • Pull the molex connectors out of the posterior end of the optical drive.
  7. HP Media Center 876x Optical Drive Replacement: 7 단계, 이미지 3개 중 1개 HP Media Center 876x Optical Drive Replacement: 7 단계, 이미지 3개 중 2개 HP Media Center 876x Optical Drive Replacement: 7 단계, 이미지 3개 중 3개
    • Pull the ribbon cable out of the back of the optical drive.
  8. HP Media Center 876x Optical Drive Replacement: 8 단계, 이미지 3개 중 1개 HP Media Center 876x Optical Drive Replacement: 8 단계, 이미지 3개 중 2개 HP Media Center 876x Optical Drive Replacement: 8 단계, 이미지 3개 중 3개
    • Using the Phillips #0 screwdriver, remove the two 5 mm screws that fasten the optical drive into its port.
    • Gently pull the optical drive through the front cavity.
  9. HP Media Center 876x Optical Drive Replacement: 9 단계, 이미지 2개 중 1개 HP Media Center 876x Optical Drive Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the optical drive completely from its port.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Balakrishnan Pillai
회원 가입일: 03/26/14
1,003 평판
안내서 8개를 작성함
Clemson, Team 6-1, Benson Spring 2014 Clemson, Team 6-1, Benson Spring 2014 회원
CLEM-BENSON-S14S6G1
3 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 5
전체 시간: 527
