주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
HP Mini 1000 Motherboard Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. HP Mini 1000 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • If present, remove the large piece of black adhesive film covering the area around the fan.
  2. HP Mini 1000 Motherboard Replacement: 2 단계, 이미지 1/2 HP Mini 1000 Motherboard Replacement: 2 단계, 이미지 2/2
    • If present, remove the pieces of black cloth tape securing the antenna cables to the motherboard.
  3. HP Mini 1000 Motherboard Replacement: 3 단계, 이미지 1/2 HP Mini 1000 Motherboard Replacement: 3 단계, 이미지 2/2
    • Use the flat end of a spudger or your fingers to disconnect the following cables:
    • Speaker cable
    • Microphone cable
    • Fan cable
    • Power cable
    • Display data cable
    • Do not lift the connectors up as you disconnect them from the motherboard. Push the connectors out of their sockets parallel to the face of the logic board toward the display assembly. Use extra care when disconnecting the display data cable, as its connector and socket are fragile.
  4. HP Mini 1000 Motherboard Replacement: 4 단계, 이미지 1/2 HP Mini 1000 Motherboard Replacement: 4 단계, 이미지 2/2
    • Remove the 2.5 mm Phillips screw securing the power switch lever to the lower case.
    • Use a pair of tweezers or your fingers to lift the power switch lever out of the Mini 1000.
  5. HP Mini 1000 Motherboard Replacement: 5 단계, 이미지 1/2 HP Mini 1000 Motherboard Replacement: 5 단계, 이미지 2/2
    • Remove the 2.5 mm Phillips screw securing the wireless on/off switch lever to the lower case.
    • Use tweezers or your fingers to remove the wireless on/off switch lever from the Mini 1000.
  6. HP Mini 1000 Motherboard Replacement: 6 단계, 이미지 1/2 HP Mini 1000 Motherboard Replacement: 6 단계, 이미지 2/2
    • Remove the two 3 mm Phillips screws securing the USB bracket to the lower case.
    • Pry up the USB bracket and remove it from the motherboard.
  7. HP Mini 1000 Motherboard Replacement: 7 단계, 이미지 1/1
    • Remove the single 4.5 mm Phillips screw securing the motherboard to the lower case near the fan.
  8. HP Mini 1000 Motherboard Replacement: 8 단계, 이미지 1/2 HP Mini 1000 Motherboard Replacement: 8 단계, 이미지 2/2
    • Carefully lift the motherboard from its right edge and remove it from the lower case, minding any cables that may get caught.
결론
Walter Galan
694,561 평판
안내서 1,203개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 70
