주요 콘텐츠로 건너뛰기
HP Mini 110-1046NR Battery Replacement
  1. HP Mini 110-1046NR Battery Replacement, Battery: 1 단계, 이미지 1/3 HP Mini 110-1046NR Battery Replacement, Battery: 1 단계, 이미지 2/3 HP Mini 110-1046NR Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Power-off the netbook fully before attempting to remove the battery.
    • Flip your netbook upside down, and locate the sliding tabs near the battery.
    • Slide both tabs inward so that the battery visibly moves away from the case of the computer.
    • Release the tabs and pull the battery out.
결론
To install a new battery or re-install the one you removed, simply press it into the slot until both tabs snap back to their outward-most position
다른 2명이 해당 안내서를 완성하였습니다.
Amos Hine
회원 가입일: 10/18/13
1,275 평판
안내서 7개 작성하였습니다
Clemson, Team 14-1, Benson Fall 2013 Clemson, Team 14-1, Benson Fall 2013 회원
CLEM-BENSON-F13S14G1
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 15
전체 시간: 3,839
