주요 콘텐츠로 건너뛰기
HP Mini 110-1046NR Memory Card Replacement
필요한 것
  1. HP Mini 110-1046NR Memory Card Replacement, Battery: 1 단계, 이미지 3개 중 1개 HP Mini 110-1046NR Memory Card Replacement, Battery: 1 단계, 이미지 3개 중 2개 HP Mini 110-1046NR Memory Card Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Power-off the netbook fully before attempting to remove the battery.
    • Flip your netbook upside down, and locate the sliding tabs near the battery.
    • Slide both tabs inward so that the battery visibly moves away from the case of the computer.
    • Release the tabs and pull the battery out.
  2. HP Mini 110-1046NR Memory Card Replacement, Memory Card Cover: 2 단계, 이미지 3개 중 1개 HP Mini 110-1046NR Memory Card Replacement, Memory Card Cover: 2 단계, 이미지 3개 중 2개 HP Mini 110-1046NR Memory Card Replacement, Memory Card Cover: 2 단계, 이미지 3개 중 3개
    • Flip the netbook over so you are looking at the bottom, and locate the two screws that hold the memory card cover.
    • Next, take a Phillips PH1 screwdriver and unscrew the two screws.
    • These screws will not release from the cover once they are unscrewed.
    • If necessary, use the flat end of the spudger to assist in prying the cover away from the computer.
  3. HP Mini 110-1046NR Memory Card Replacement, Memory Card: 3 단계, 이미지 3개 중 1개 HP Mini 110-1046NR Memory Card Replacement, Memory Card: 3 단계, 이미지 3개 중 2개 HP Mini 110-1046NR Memory Card Replacement, Memory Card: 3 단계, 이미지 3개 중 3개
    • Carefully push the clips to the side, away from the memory card.
    • Note: The memory module is spring-loaded and will pop out when the clips are detatched.
    • Slide the memory card straight out, holding it as shown to avoid getting skin oils on the electrical contacts.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Jared Cooper
회원 가입일: 10/18/13
649 평판
안내서 5개를 작성함
Clemson, Team 14-1, Benson Fall 2013 Clemson, Team 14-1, Benson Fall 2013 회원
CLEM-BENSON-F13S14G1
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 15
전체 시간: 1,445
