주요 콘텐츠로 건너뛰기
HP Mini 110-3131dx Hard Drive Replacement
필요한 것
    • Power off the laptop before trying to remove the battery.
    • Turn the laptop upside down, and locate the sliding tabs on the battery.
    • Slide both tabs in an inward direction, then slide the battery away from the laptop.
  1. HP Mini 110-3131dx Hard Drive Replacement, Back Cover: 2 단계, 이미지 1/2 HP Mini 110-3131dx Hard Drive Replacement, Back Cover: 2 단계, 이미지 2/2
    • To remove the bottom cover pull the orange tab to the right until it clicks.
    • Carefully disconnect the clips as you lift the bottom cover.
  2. HP Mini 110-3131dx Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/1
    • Remove the four screws holding down the hard drive using a Phillips #1 screwdriver.
  3. HP Mini 110-3131dx Hard Drive Replacement: 4 단계, 이미지 1/2 HP Mini 110-3131dx Hard Drive Replacement: 4 단계, 이미지 2/2
    • Lift the black flap covering the hard drive then slide it towards the left using the orange tab until it's released from its receptacle.
    • Pull the hard drive out of the laptop.
    • Put the hard drive in an anti-static bag to decrease the likelihood of harming it with static electricity.
결론
To reinstall a new or old hard drive, follow these instructions in reverse order.
다른 3명이 해당 안내서를 완성하였습니다.
aarondcollege
회원 가입일: 10/06/16
1,297 평판
안내서 10개 작성하였습니다
USF Tampa, Team 2-4, Cagle Fall 2016 USF Tampa, Team 2-4, Cagle Fall 2016 회원
USFT-CAGLE-F16S2G4
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 1,389
