주요 콘텐츠로 건너뛰기
HP Mini 110-3131dx Keyboard Replacement
필요한 것
    • Power off the laptop before trying to remove the battery.
    • Turn the laptop upside down, and locate the sliding tabs on the battery.
    • Slide both tabs in an inward direction, then slide the battery away from the laptop.
  1. HP Mini 110-3131dx Keyboard Replacement, Back Cover: 2 단계, 이미지 1/2 HP Mini 110-3131dx Keyboard Replacement, Back Cover: 2 단계, 이미지 2/2
    • To remove the bottom cover pull the orange tab to the right until it clicks.
    • Carefully disconnect the clips as you lift the bottom cover.
  2. HP Mini 110-3131dx Keyboard Replacement, Keyboard: 3 단계, 이미지 1/1
    • Remove the three black screws marked by the keyboard symbol using a Phillips #1 screwdriver.
  3. HP Mini 110-3131dx Keyboard Replacement: 4 단계, 이미지 1/3 HP Mini 110-3131dx Keyboard Replacement: 4 단계, 이미지 2/3 HP Mini 110-3131dx Keyboard Replacement: 4 단계, 이미지 3/3
    • Turn the laptop upright and open it.
    • Disconnect the clips located around the perimeter of the keyboard.
    • Slide the iFixit opening tool between the top edge of the keyboard and the plastic bezel.
    • Start either above the esc key or the delete key.
    • Pull the keyboard with your fingers until it comes out on both sides.
    • Be careful not to pull the keyboard out too fast. There is a fragile ribbon cable that attaches to the motherboard behind the keyboard.
  4. HP Mini 110-3131dx Keyboard Replacement: 5 단계, 이미지 1/1
    • Tilt the keyboard toward you to reveal the ribbon cable.
    • Lift up the black tab on top of the keyboard ribbon cable to release the ribbon cable.
    • Pull the ribbon cable out of its container.
결론
To install a different keyboard, follow these instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
aarondcollege
회원 가입일: 10/06/16
1,297 평판
안내서 10개 작성하였습니다
USF Tampa, Team 2-4, Cagle Fall 2016 USF Tampa, Team 2-4, Cagle Fall 2016 회원
USFT-CAGLE-F16S2G4
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 15
전체 시간: 2,172
