주요 콘텐츠로 건너뛰기
HP Mini 110-3131dx Memory Card Replacement
필요한 것
    • Power off the laptop before trying to remove the battery.
    • Turn the laptop upside down, and locate the sliding tabs on the battery.
    • Slide both tabs in an inward direction, then slide the battery away from the laptop.
  1. HP Mini 110-3131dx Memory Card Replacement, Back Cover: 2 단계, 이미지 1/2 HP Mini 110-3131dx Memory Card Replacement, Back Cover: 2 단계, 이미지 2/2
    • To remove the bottom cover pull the orange tab to the right until it clicks.
    • Carefully disconnect the clips as you lift the bottom cover.
  2. HP Mini 110-3131dx Memory Card Replacement, Memory Card: 3 단계, 이미지 1/3 HP Mini 110-3131dx Memory Card Replacement, Memory Card: 3 단계, 이미지 2/3 HP Mini 110-3131dx Memory Card Replacement, Memory Card: 3 단계, 이미지 3/3
    • Find the two silver screws that hold the memory card cover.
    • Take a PH1 screwdriver and unscrew the two screws.
    • Remove the metal cover
  3. HP Mini 110-3131dx Memory Card Replacement: 4 단계, 이미지 1/2 HP Mini 110-3131dx Memory Card Replacement: 4 단계, 이미지 2/2
    • Pull the two white tabs located on either side of the memory card away from each other until the card pops up
    • Remove the card
결론
To install the new memory card, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
aarondcollege
회원 가입일: 10/06/16
1,297 평판
안내서 10개 작성하였습니다
USF Tampa, Team 2-4, Cagle Fall 2016 USF Tampa, Team 2-4, Cagle Fall 2016 회원
USFT-CAGLE-F16S2G4
5 회원들
안내서 10개 작성하였습니다
댓글 한 개
what ram she using hp mini
ASKAR MALAYA - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 10
전체 시간: 661
