주요 콘텐츠로 건너뛰기
HP Mini 110-3735dx Backcover Replacement
  1. HP Mini 110-3735dx Backcover Replacement, Battery: 1 단계, 이미지 1/3 HP Mini 110-3735dx Backcover Replacement, Battery: 1 단계, 이미지 2/3 HP Mini 110-3735dx Backcover Replacement, Battery: 1 단계, 이미지 3/3
    • With the bottom of the HP Mini facing up, slide both switches inward towards each other.
  2. HP Mini 110-3735dx Backcover Replacement: 2 단계, 이미지 1/2 HP Mini 110-3735dx Backcover Replacement: 2 단계, 이미지 2/2
    • With the left switch still pushed inward, pull the battery towards you to remove it from the computer.
  3. HP Mini 110-3735dx Backcover Replacement, Backcover: 3 단계, 이미지 1/3 HP Mini 110-3735dx Backcover Replacement, Backcover: 3 단계, 이미지 2/3 HP Mini 110-3735dx Backcover Replacement, Backcover: 3 단계, 이미지 3/3
    • Pull upward from under the back cover via the missing battery area.
    • Best to start from one of the corners.
결론
Tyrone Williams
회원 가입일: 03/10/16
905 평판
안내서 7개 작성하였습니다
UMass Dartmouth, Team 4-1, Catania Spring 2016 UMass Dartmouth, Team 4-1, Catania Spring 2016 회원
UMASSD-CATANIA-S16S4G1
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 483
