주요 콘텐츠로 건너뛰기
HP Mini 110-3735dx Hard Drive Replacement
필요한 것
  1. HP Mini 110-3735dx Hard Drive Replacement, Battery: 1 단계, 이미지 1/3 HP Mini 110-3735dx Hard Drive Replacement, Battery: 1 단계, 이미지 2/3 HP Mini 110-3735dx Hard Drive Replacement, Battery: 1 단계, 이미지 3/3
    • With the bottom of the HP Mini facing up, slide both switches inward towards each other.
  2. HP Mini 110-3735dx Hard Drive Replacement: 2 단계, 이미지 1/2 HP Mini 110-3735dx Hard Drive Replacement: 2 단계, 이미지 2/2
    • With the left switch still pushed inward, pull the battery towards you to remove it from the computer.
  3. HP Mini 110-3735dx Hard Drive Replacement, Backcover: 3 단계, 이미지 1/3 HP Mini 110-3735dx Hard Drive Replacement, Backcover: 3 단계, 이미지 2/3 HP Mini 110-3735dx Hard Drive Replacement, Backcover: 3 단계, 이미지 3/3
    • Pull upward from under the back cover via the missing battery area.
    • Best to start from one of the corners.
  4. HP Mini 110-3735dx Hard Drive Replacement, Hard Drive Cage: 4 단계, 이미지 1/1
    • Remove the three 5.0 mm screws holding the hard drive cage in place using a Phillips #1 screw driver.
  5. HP Mini 110-3735dx Hard Drive Replacement: 5 단계, 이미지 1/3 HP Mini 110-3735dx Hard Drive Replacement: 5 단계, 이미지 2/3 HP Mini 110-3735dx Hard Drive Replacement: 5 단계, 이미지 3/3
    • Lift the hard drive cage by pulling the tape upward.
    • Start by pulling the tape from the side with the keyboard symbol.
  6. HP Mini 110-3735dx Hard Drive Replacement: 6 단계, 이미지 1/2 HP Mini 110-3735dx Hard Drive Replacement: 6 단계, 이미지 2/2
    • Unplug the cable connecting to the hard drive.
  7. HP Mini 110-3735dx Hard Drive Replacement, Hard Drive: 7 단계, 이미지 1/3 HP Mini 110-3735dx Hard Drive Replacement, Hard Drive: 7 단계, 이미지 2/3 HP Mini 110-3735dx Hard Drive Replacement, Hard Drive: 7 단계, 이미지 3/3
    • Remove the four 4.0 mm screws on both sides of the cage using a Phillips #1 screw driver.
  8. HP Mini 110-3735dx Hard Drive Replacement: 8 단계, 이미지 1/3 HP Mini 110-3735dx Hard Drive Replacement: 8 단계, 이미지 2/3 HP Mini 110-3735dx Hard Drive Replacement: 8 단계, 이미지 3/3
    • Gently remove the hard drive from it's cage.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tyrone Williams
회원 가입일: 03/10/16
905 평판
안내서 7개 작성하였습니다
UMass Dartmouth, Team 4-1, Catania Spring 2016 UMass Dartmouth, Team 4-1, Catania Spring 2016 회원
UMASSD-CATANIA-S16S4G1
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 640
