이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
With the bottom of the HP Mini facing up, slide both switches inward towards each other.
With the left switch still pushed inward, pull the battery towards you to remove it from the computer.
Remove the three 4.0 mm screws with the keyboard indicator next to them using a Phillips #1 screw driver.
With the keyboard facing you, pull the black bezel upward until its loose.
Move and hold the bezel slightly towards the screen while lifting the keyboard from the top.
Pull up the keyboard from the bottom corners exposing the keyboard cable.
Lift the black holder connected to the keyboard cable until it points up.
