소개
If your screen is damaged, flicking, or cracked, use this guide to replace the screen.
필요한 것
With the bottom of the HP Mini facing up, slide both switches inward towards each other.
Remove the three 4.0 mm screws with the keyboard indicator next to them using a Phillips #1 screw driver.
Remove the three 5.0 mm screws holding the hard drive cage in place using a Phillips #1 screw driver.
댓글 한 개
Tengo una pregunta en pantalla habrá alguna otra que sea compatible con esta hp sin ser el mismo modelo?
Icela Ross - 답글
