주요 콘텐츠로 건너뛰기
HP Mini 110-3735dx Screen Replacement
필요한 것
  1. HP Mini 110-3735dx Screen Replacement, Battery: 1 단계, 이미지 1/3 HP Mini 110-3735dx Screen Replacement, Battery: 1 단계, 이미지 2/3 HP Mini 110-3735dx Screen Replacement, Battery: 1 단계, 이미지 3/3
    • With the bottom of the HP Mini facing up, slide both switches inward towards each other.
  2. HP Mini 110-3735dx Screen Replacement: 2 단계, 이미지 1/2 HP Mini 110-3735dx Screen Replacement: 2 단계, 이미지 2/2
    • With the left switch still pushed inward, pull the battery towards you to remove it from the computer.
  3. HP Mini 110-3735dx Screen Replacement, Backcover: 3 단계, 이미지 1/3 HP Mini 110-3735dx Screen Replacement, Backcover: 3 단계, 이미지 2/3 HP Mini 110-3735dx Screen Replacement, Backcover: 3 단계, 이미지 3/3
    • Pull upward from under the back cover via the missing battery area.
    • Best to start from one of the corners.
  4. HP Mini 110-3735dx Screen Replacement, Keyboard: 4 단계, 이미지 1/2 HP Mini 110-3735dx Screen Replacement, Keyboard: 4 단계, 이미지 2/2
    • Remove the three 4.0 mm screws with the keyboard indicator next to them using a Phillips #1 screw driver.
  5. HP Mini 110-3735dx Screen Replacement: 5 단계, 이미지 1/2 HP Mini 110-3735dx Screen Replacement: 5 단계, 이미지 2/2
    • Flip the laptop over, and open it up.
    • Don't worry! No pieces will fall out.
  6. HP Mini 110-3735dx Screen Replacement: 6 단계, 이미지 1/2 HP Mini 110-3735dx Screen Replacement: 6 단계, 이미지 2/2
    • With the keyboard facing you, pull the black bezel upward until its loose.
    • You should hear three clicks.
  7. HP Mini 110-3735dx Screen Replacement: 7 단계, 이미지 1/2 HP Mini 110-3735dx Screen Replacement: 7 단계, 이미지 2/2
    • Move and hold the bezel slightly towards the screen while lifting the keyboard from the top.
  8. HP Mini 110-3735dx Screen Replacement: 8 단계, 이미지 1/1
    • Pull up the keyboard from the bottom corners exposing the keyboard cable.
  9. HP Mini 110-3735dx Screen Replacement: 9 단계, 이미지 1/2 HP Mini 110-3735dx Screen Replacement: 9 단계, 이미지 2/2
    • Lift the black holder connected to the keyboard cable until it points up.
  10. HP Mini 110-3735dx Screen Replacement: 10 단계, 이미지 1/2 HP Mini 110-3735dx Screen Replacement: 10 단계, 이미지 2/2
    • Gently pull the keyboard cable from the socket.
  11. HP Mini 110-3735dx Screen Replacement, Hard Drive Cage: 11 단계, 이미지 1/1
    • Remove the three 5.0 mm screws holding the hard drive cage in place using a Phillips #1 screw driver.
  12. HP Mini 110-3735dx Screen Replacement: 12 단계, 이미지 1/3 HP Mini 110-3735dx Screen Replacement: 12 단계, 이미지 2/3 HP Mini 110-3735dx Screen Replacement: 12 단계, 이미지 3/3
    • Lift the hard drive cage by pulling the tape upward.
    • Start by pulling the tape from the side with the keyboard symbol.
  13. HP Mini 110-3735dx Screen Replacement: 13 단계, 이미지 1/2 HP Mini 110-3735dx Screen Replacement: 13 단계, 이미지 2/2
    • Unplug the cable connecting to the hard drive.
  14. HP Mini 110-3735dx Screen Replacement, Screen: 14 단계, 이미지 1/2 HP Mini 110-3735dx Screen Replacement, Screen: 14 단계, 이미지 2/2
    • Remove the 8 5.0 mm screws under the keyboard using a Phillips #1 screw driver.
  15. HP Mini 110-3735dx Screen Replacement: 15 단계, 이미지 1/3 HP Mini 110-3735dx Screen Replacement: 15 단계, 이미지 2/3 HP Mini 110-3735dx Screen Replacement: 15 단계, 이미지 3/3
    • Lift the two black holders upward located next to the socket for the keyboard close to the tracked pad.
  16. HP Mini 110-3735dx Screen Replacement: 16 단계, 이미지 1/2 HP Mini 110-3735dx Screen Replacement: 16 단계, 이미지 2/2
    • Remove the two connectors for the motherboard from their sockets.
  17. HP Mini 110-3735dx Screen Replacement: 17 단계, 이미지 1/2 HP Mini 110-3735dx Screen Replacement: 17 단계, 이미지 2/2
    • Close the laptop by bringing the screen down.
    • Flip the laptop over to the other side.
  18. HP Mini 110-3735dx Screen Replacement: 18 단계, 이미지 1/2 HP Mini 110-3735dx Screen Replacement: 18 단계, 이미지 2/2
    • Remove the 6 5.0 mm screws holding the back plate together using a Phillips #1 screw driver.
  19. HP Mini 110-3735dx Screen Replacement: 19 단계, 이미지 1/2 HP Mini 110-3735dx Screen Replacement: 19 단계, 이미지 2/2
    • Remove the 2 3.0 mm screw head holding the plastic piece in place using a Phillips #1 screw driver.
    • Located on the left and right side where the battery was removed.
  20. HP Mini 110-3735dx Screen Replacement: 20 단계, 이미지 1/3 HP Mini 110-3735dx Screen Replacement: 20 단계, 이미지 2/3 HP Mini 110-3735dx Screen Replacement: 20 단계, 이미지 3/3
    • Pull the black plastic pieces that the screws was holding inward.
    • The pieces are located on the left and right corners connecting the bottom and top of the HP Mini.
  21. HP Mini 110-3735dx Screen Replacement: 21 단계, 이미지 1/2 HP Mini 110-3735dx Screen Replacement: 21 단계, 이미지 2/2
    • Flip the laptop back over.
    • Open it by lifting the screeen.
  22. HP Mini 110-3735dx Screen Replacement: 22 단계, 이미지 1/3 HP Mini 110-3735dx Screen Replacement: 22 단계, 이미지 2/3 HP Mini 110-3735dx Screen Replacement: 22 단계, 이미지 3/3
    • Right next to the previous plastic piece, remove the other two plastic pieces.
    • This may be difficult to come off. Tilt the screen back and forth to help loosen the piece.
  23. HP Mini 110-3735dx Screen Replacement: 23 단계, 이미지 1/1
    • Using the plastic prying tool, pry the front plate of the bottom part of your HP Mini.
    • Start along the speaker grill near the touch pad, and move along the sides.
  24. HP Mini 110-3735dx Screen Replacement: 24 단계, 이미지 1/2 HP Mini 110-3735dx Screen Replacement: 24 단계, 이미지 2/2
    • Lift up the front plate where the keyboard was.
  25. HP Mini 110-3735dx Screen Replacement: 25 단계, 이미지 1/3 HP Mini 110-3735dx Screen Replacement: 25 단계, 이미지 2/3 HP Mini 110-3735dx Screen Replacement: 25 단계, 이미지 3/3
    • Remove the display cable from the motherboard located on the top left corner under where the keyboard was by pulling on the black tab.
    • Move the cable.
  26. HP Mini 110-3735dx Screen Replacement: 26 단계, 이미지 1/3 HP Mini 110-3735dx Screen Replacement: 26 단계, 이미지 2/3 HP Mini 110-3735dx Screen Replacement: 26 단계, 이미지 3/3
    • Remove the webcam cables from the motherboard.
    • Located on the back side of the laptop in the bottom left corner.
  27. HP Mini 110-3735dx Screen Replacement: 27 단계, 이미지 1/1
    • Flip over the computer, and open the laptop.
    • Lift up the front plate on the top right corner.
  28. HP Mini 110-3735dx Screen Replacement: 28 단계, 이미지 1/3 HP Mini 110-3735dx Screen Replacement: 28 단계, 이미지 2/3 HP Mini 110-3735dx Screen Replacement: 28 단계, 이미지 3/3
    • Pull the cables for the web cam out using tweezers.
  29. HP Mini 110-3735dx Screen Replacement: 29 단계, 이미지 1/2 HP Mini 110-3735dx Screen Replacement: 29 단계, 이미지 2/2
    • Remove the 2 3.0 mm screws on both sides of the bottom of the display using a Phillips #1 screwdriver.
  30. HP Mini 110-3735dx Screen Replacement: 30 단계, 이미지 1/2 HP Mini 110-3735dx Screen Replacement: 30 단계, 이미지 2/2
    • Remove the black plastic piece that the screw was holding on both sides.
    • This will reveal another screw.
  31. HP Mini 110-3735dx Screen Replacement: 31 단계, 이미지 1/2 HP Mini 110-3735dx Screen Replacement: 31 단계, 이미지 2/2
    • Remove the 2 3.0 mm screws on both sides using a Phillips #1 screw driver.
    • When removing, keep hold of the screen to make sure it doesn't fall.
  32. HP Mini 110-3735dx Screen Replacement: 32 단계, 이미지 1/1
    • Pry the front plate using the plastic opening tool by pushing along the border of the front and back plate.
    • Make sure to pry from the sides, top and bottom as the corners will come undone themselves.
  33. HP Mini 110-3735dx Screen Replacement: 33 단계, 이미지 1/3 HP Mini 110-3735dx Screen Replacement: 33 단계, 이미지 2/3 HP Mini 110-3735dx Screen Replacement: 33 단계, 이미지 3/3
    • Remove the front plate.
    • Pull the cables through the holes.
  34. HP Mini 110-3735dx Screen Replacement: 34 단계, 이미지 1/2 HP Mini 110-3735dx Screen Replacement: 34 단계, 이미지 2/2
    • Remove the 4 4.0 mm screws holding the screen in place using a Phillips #1 screw driver.
  35. HP Mini 110-3735dx Screen Replacement: 35 단계, 이미지 1/2 HP Mini 110-3735dx Screen Replacement: 35 단계, 이미지 2/2
    • Lift the screen up.
  36. HP Mini 110-3735dx Screen Replacement: 36 단계, 이미지 1/2 HP Mini 110-3735dx Screen Replacement: 36 단계, 이미지 2/2
    • Under the screen, peel off the tape near the cable completely, so you can see the socket for the cable.
결론
Tyrone Williams
회원 가입일: 03/10/16
905 평판
안내서 7개 작성하였습니다
UMass Dartmouth, Team 4-1, Catania Spring 2016 UMass Dartmouth, Team 4-1, Catania Spring 2016 회원
UMASSD-CATANIA-S16S4G1
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
Tengo una pregunta en pantalla habrá alguna otra que sea compatible con esta hp sin ser el mismo modelo?
Icela Ross - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 10
전체 시간: 778
