이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
If the system clock or the BIOS (Basic Input/Output System) settings reset when the netbook is turned off, the CMOS (Complementary Metal-Oxide Semiconductor) battery may need to be replaced.
The CMOS battery should be replaced with a 3-volt 2032-size coin battery.
필요한 것
Hold the netbook top-side down with the lid closed.
Slide the plastic battery release latches towards the lock symbols.
Turn the netbook to view its edge.
Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
Cut one side of the black adhesive ribbon on top of the CMOS battery with a utility blade.
다른 8명이 해당 안내서를 완성하였습니다.
댓글 한 개
after need CMOS reset. Screen is black. Is there an easy way on my HP Mini 210?
