주요 콘텐츠로 건너뛰기
HP Mini 210 Hard Drive Replacement
필요한 것
  1. HP Mini 210 Hard Drive Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Mini 210 Hard Drive Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn off and unplug the netbook before replacing the battery.
    • Hold the netbook top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
    • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
  2. HP Mini 210 Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the battery out from the netbook.
  3. HP Mini 210 Hard Drive Replacement, Disassembling HP Mini 210 Back Case: 3 단계, 이미지 1개 중 1개
    • Turn the netbook to view its edge.
    • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
  4. HP Mini 210 Hard Drive Replacement: 4 단계, 이미지 1개 중 1개
    • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
  5. HP Mini 210 Hard Drive Replacement: 5 단계, 이미지 1개 중 1개
    • Pull the back case off from the front edge.
  6. HP Mini 210 Hard Drive Replacement, Hard Drive: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Peel back the black sticker covering the hard drive with tweezers or your fingers.
  7. HP Mini 210 Hard Drive Replacement: 7 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to carefully disconnect the hard drive connector found above the RAM slot.
  8. HP Mini 210 Hard Drive Replacement: 8 단계, 이미지 2개 중 1개 HP Mini 210 Hard Drive Replacement: 8 단계, 이미지 2개 중 2개
    • Pull the silver plastic tab up and remove the hard drive. The tab may also be black.
    • Be aware of the 4 foam cushions on each corner of the hard drive as they may become loose during removal.
결론
다른 14명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Heather Freed
회원 가입일: 10/06/12
723 평판
안내서 8개를 작성함
Cal Poly, Team 9-17, Amido Fall 2012 Cal Poly, Team 9-17, Amido Fall 2012 회원
CPSU-AMIDO-F12S9G17
3 회원들
안내서 8개를 작성함
1가이드 댓글
Be aware that some models don't have buttons but a orange switch that need some pressure to release the cover
Alejandro - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 36
전체 시간: 18,739
