주요 콘텐츠로 건너뛰기
HP Mini 210 Netbook WWAN Card Replacement
필요한 것
  1. HP Mini 210 Netbook WWAN Card Replacement, WWAN Card: 1 단계, 이미지 1/1
    • Turn off and unplug the netbook before replacing the battery.
    • Hold the netbook top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
    • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
  2. HP Mini 210 Netbook WWAN Card Replacement: 2 단계, 이미지 1/1
    • Slide the battery out from the netbook.
  3. HP Mini 210 Netbook WWAN Card Replacement: 3 단계, 이미지 1/1
    • Turn the netbook to view its edge.
    • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
  4. HP Mini 210 Netbook WWAN Card Replacement: 4 단계, 이미지 1/1
    • Use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
  5. HP Mini 210 Netbook WWAN Card Replacement: 5 단계, 이미지 1/1
    • Pull the back case off from the front edge.
  6. HP Mini 210 Netbook WWAN Card Replacement: 6 단계, 이미지 1/2 HP Mini 210 Netbook WWAN Card Replacement: 6 단계, 이미지 2/2
    • Disconnect the two gold antenna cables from the WWAN card using a plastic opening tool.
  7. HP Mini 210 Netbook WWAN Card Replacement: 7 단계, 이미지 1/2 HP Mini 210 Netbook WWAN Card Replacement: 7 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the two Phillips 2.0 and 3.0 mm screws that secure the WWAN to the system board.
  8. HP Mini 210 Netbook WWAN Card Replacement: 8 단계, 이미지 1/1
    • Remove the WWAN card by pulling the WWAN card out at an angle.
결론
Install the new WWAN card and then to reassemble your device, follow these instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Heather Freed
회원 가입일: 10/06/12
723 평판
안내서 8개 작성하였습니다
Cal Poly, Team 9-17, Amido Fall 2012 Cal Poly, Team 9-17, Amido Fall 2012 회원
CPSU-AMIDO-F12S9G17
3 회원들
안내서 8개 작성하였습니다
댓글 2개
apakah benda tersebut ada dalam paket penjualan, atau dijual terpisah?
rioarayana - 답글
I wonder sims slot on hp mini and other major brands also. Toshiba ,Acer
Deborah Kisilywicz - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 5,712
