주요 콘텐츠로 건너뛰기
HP Mini 210 WiFi Card Replacement
필요한 것
  1. HP Mini 210 WiFi Card Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Mini 210 WiFi Card Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn off and unplug the netbook before replacing the battery.
    • Hold the netbook top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
    • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
  2. HP Mini 210 WiFi Card Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the battery out from the netbook.
  3. HP Mini 210 WiFi Card Replacement, Disassembling HP Mini 210 Back Case: 3 단계, 이미지 1개 중 1개
    • Turn the netbook to view its edge.
    • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
  4. HP Mini 210 WiFi Card Replacement: 4 단계, 이미지 1개 중 1개
    • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
  5. HP Mini 210 WiFi Card Replacement: 5 단계, 이미지 1개 중 1개
    • Pull the back case off from the front edge.
  6. HP Mini 210 WiFi Card Replacement, WiFi Card: 6 단계, 이미지 1개 중 1개
    • Pop out the two gold connectors from the antenna wires on top of the WiFi card using a plastic opening tool. This will allow you to dislodge the WiFi card from the rest of the netbook.
  7. HP Mini 210 WiFi Card Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the two 3.9 mm screws on top of the WiFi card using the Phillips #00 screwdriver.
  8. HP Mini 210 WiFi Card Replacement: 8 단계, 이미지 1개 중 1개
    • Gently pull the WiFi card out of its slot. Be sure to pull the card up and out of the slot towards you.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
14다른 기여자 명과 함께
Heather Freed
회원 가입일: 10/06/12
723 평판
안내서 8개를 작성함
Cal Poly, Team 9-17, Amido Fall 2012 Cal Poly, Team 9-17, Amido Fall 2012 회원
CPSU-AMIDO-F12S9G17
3 회원들
안내서 8개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 24
전체 시간: 5,483
