소개
Use this guide to replace the keyboard on your HP Mini 210-1035la.
필요한 것
Shut down the computer
Flip the computer upside down
Remove the battery by sliding its tabs in and pulling it away from the laptop.
Simultaneously press in on the right release button (1) to release the right side ofrece the service cover (2)
Simultaneously press in on the left release button (3) to release the left side of the service cover (4)
Remove the three screws (circled in red) that hold the keyboard
With the computer facing you, turn it right-side up.
Completely open the computer
Lift the back edge of the key board until it rest at an angle
Slide the keyboard back until the keyboard cable and connector are accessible
Release the connector to which the keyboard cable has been attaching, and then disconnect the keyboard cable
Remove the keyboard
다른 3명이 해당 안내서를 완성하였습니다.
