주요 콘텐츠로 건너뛰기
HP Mini 210-1199DX Bottom Cover Replacement
필요한 것
  1. HP Mini 210-1199DX Bottom Cover Replacement, Battery: 1 단계, 이미지 1/2 HP Mini 210-1199DX Bottom Cover Replacement, Battery: 1 단계, 이미지 2/2
    • Unplug the netbook.
    • Secure the netbook in a upright position.
    • Slide the plastic battery latch that secures it into the netbook.
    • Keep thumb secure on the right tab as you begin to remove the battery.
  2. HP Mini 210-1199DX Bottom Cover Replacement: 2 단계, 이미지 1/1
    • Remove the battery from the device.
  3. HP Mini 210-1199DX Bottom Cover Replacement, Bottom Cover: 3 단계, 이미지 1/1
    • Press down on the two orange buttons to release.
    • If the case does not pop off, begin to use Spudger to pry the case off the back.
  4. HP Mini 210-1199DX Bottom Cover Replacement: 4 단계, 이미지 1/3 HP Mini 210-1199DX Bottom Cover Replacement: 4 단계, 이미지 2/3 HP Mini 210-1199DX Bottom Cover Replacement: 4 단계, 이미지 3/3
    • Place the spudger on corners and openings in order to begin removal of the back.
    • Continue this on all corner until the case comes fully off of the back.
  5. HP Mini 210-1199DX Bottom Cover Replacement: 5 단계, 이미지 1/1
    • Pull the case off of the device
결론
Phillip Winston
회원 가입일: 03/21/17
655 평판
안내서 6개 작성하였습니다
Texas Tech, Team S46-G3, Bennett Spring 2017 Texas Tech, Team S46-G3, Bennett Spring 2017 회원
TTU-BENNETT-S17S46G3
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
Awesome tip about the release buttons. Once I got it off I noted the eject latch only runs halfway down the device and the rubber feet are actually attached to the frame not the bottom cover which just has holes for them to protrude through.
I wanted to get the bottom off in order to verify the AC adapter Voltage, Amperage and Polarity (which I think ios the same for the whole 210 line.
I guess I’ll upgrade to an SSD and increase the RAM while it’s open..
Power specs for my model: HP Mini 210 1075CA: 19.5Vdc, 2.05A, with polarity being ++''inside & - -''outside .
osearth esp - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 301
