주요 콘텐츠로 건너뛰기
HP Mini 210-1199DX CMOS Battery Replacement
필요한 것
  1. HP Mini 210-1199DX CMOS Battery Replacement, Battery: 1 단계, 이미지 1/2 HP Mini 210-1199DX CMOS Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Unplug the netbook.
    • Secure the netbook in a upright position.
    • Slide the plastic battery latch that secures it into the netbook.
    • Keep thumb secure on the right tab as you begin to remove the battery.
  2. HP Mini 210-1199DX CMOS Battery Replacement: 2 단계, 이미지 1/1
    • Remove the battery from the device.
  3. HP Mini 210-1199DX CMOS Battery Replacement, Bottom Cover: 3 단계, 이미지 1/1
    • Press down on the two orange buttons to release.
    • If the case does not pop off, begin to use Spudger to pry the case off the back.
  4. HP Mini 210-1199DX CMOS Battery Replacement: 4 단계, 이미지 1/3 HP Mini 210-1199DX CMOS Battery Replacement: 4 단계, 이미지 2/3 HP Mini 210-1199DX CMOS Battery Replacement: 4 단계, 이미지 3/3
    • Place the spudger on corners and openings in order to begin removal of the back.
    • Continue this on all corner until the case comes fully off of the back.
  5. HP Mini 210-1199DX CMOS Battery Replacement: 5 단계, 이미지 1/1
    • Pull the case off of the device
  6. HP Mini 210-1199DX CMOS Battery Replacement, CMOS Battery: 6 단계, 이미지 1/2 HP Mini 210-1199DX CMOS Battery Replacement, CMOS Battery: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Simply pull the small black ribbon off of the battery with either your finger or a pair of tweezers.
  7. HP Mini 210-1199DX CMOS Battery Replacement: 7 단계, 이미지 1/2 HP Mini 210-1199DX CMOS Battery Replacement: 7 단계, 이미지 2/2
    • Using the spudger, carefully pop the battery out of the right side as seen in the picture.
    • To reinstall, carefully place slide the battery back into place with the positive side facing upwards.
결론
Phillip Winston
회원 가입일: 03/21/17
655 평판
안내서 6개 작성하였습니다
Texas Tech, Team S46-G3, Bennett Spring 2017 Texas Tech, Team S46-G3, Bennett Spring 2017 회원
TTU-BENNETT-S17S46G3
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 714
