주요 콘텐츠로 건너뛰기
HP Mini 210-1199DX RAM Replacement
필요한 것
  1. HP Mini 210-1199DX RAM Replacement, Battery: 1 단계, 이미지 1/2 HP Mini 210-1199DX RAM Replacement, Battery: 1 단계, 이미지 2/2
    • Unplug the netbook.
    • Secure the netbook in a upright position.
    • Slide the plastic battery latch that secures it into the netbook.
    • Keep thumb secure on the right tab as you begin to remove the battery.
  2. HP Mini 210-1199DX RAM Replacement: 2 단계, 이미지 1/1
    • Remove the battery from the device.
  3. HP Mini 210-1199DX RAM Replacement, Bottom Cover: 3 단계, 이미지 1/1
    • Press down on the two orange buttons to release.
    • If the case does not pop off, begin to use Spudger to pry the case off the back.
  4. HP Mini 210-1199DX RAM Replacement: 4 단계, 이미지 1/3 HP Mini 210-1199DX RAM Replacement: 4 단계, 이미지 2/3 HP Mini 210-1199DX RAM Replacement: 4 단계, 이미지 3/3
    • Place the spudger on corners and openings in order to begin removal of the back.
    • Continue this on all corner until the case comes fully off of the back.
  5. HP Mini 210-1199DX RAM Replacement: 5 단계, 이미지 1/1
    • Pull the case off of the device
  6. HP Mini 210-1199DX RAM Replacement, RAM: 6 단계, 이미지 1/1
    • Locate RAM systems.
  7. HP Mini 210-1199DX RAM Replacement: 7 단계, 이미지 1/1
    • Use spudger to carefully pull the holding devices back.
    • RAM should pop out once this is completed.
  8. HP Mini 210-1199DX RAM Replacement: 8 단계, 이미지 1/1
    • Carefully pull the RAM card out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Phillip Winston
회원 가입일: 03/21/17
655 평판
안내서 6개 작성하였습니다
Texas Tech, Team S46-G3, Bennett Spring 2017 Texas Tech, Team S46-G3, Bennett Spring 2017 회원
TTU-BENNETT-S17S46G3
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 341
