주요 콘텐츠로 건너뛰기
HP Mini 210-1199DX Wireless Card Replacement
필요한 것
  1. HP Mini 210-1199DX Wireless Card Replacement, Battery: 1 단계, 이미지 1/2 HP Mini 210-1199DX Wireless Card Replacement, Battery: 1 단계, 이미지 2/2
    • Unplug the netbook.
    • Secure the netbook in a upright position.
    • Slide the plastic battery latch that secures it into the netbook.
    • Keep thumb secure on the right tab as you begin to remove the battery.
  2. HP Mini 210-1199DX Wireless Card Replacement: 2 단계, 이미지 1/1
    • Remove the battery from the device.
  3. HP Mini 210-1199DX Wireless Card Replacement, Bottom Cover: 3 단계, 이미지 1/1
    • Press down on the two orange buttons to release.
    • If the case does not pop off, begin to use Spudger to pry the case off the back.
  4. HP Mini 210-1199DX Wireless Card Replacement: 4 단계, 이미지 1/3 HP Mini 210-1199DX Wireless Card Replacement: 4 단계, 이미지 2/3 HP Mini 210-1199DX Wireless Card Replacement: 4 단계, 이미지 3/3
    • Place the spudger on corners and openings in order to begin removal of the back.
    • Continue this on all corner until the case comes fully off of the back.
  5. HP Mini 210-1199DX Wireless Card Replacement: 5 단계, 이미지 1/1
    • Pull the case off of the device
  6. HP Mini 210-1199DX Wireless Card Replacement, Wireless Card: 6 단계, 이미지 1/1
    • Locate the Wireless Card.
  7. HP Mini 210-1199DX Wireless Card Replacement: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • With fingers or tweezers, carefully pull the black and white wire connectors from their sockets and move them to the side.
  8. HP Mini 210-1199DX Wireless Card Replacement: 8 단계, 이미지 1/2 HP Mini 210-1199DX Wireless Card Replacement: 8 단계, 이미지 2/2
    • With a Phillip's Screwdriver, firmly but slowly remove the two screws from the top of the wireless card.
    • Be careful not to strip the nail head.
  9. HP Mini 210-1199DX Wireless Card Replacement: 9 단계, 이미지 1/1
    • Pull the wireless card out.
결론
Phillip Winston
회원 가입일: 03/21/17
655 평판
안내서 6개 작성하였습니다
Texas Tech, Team S46-G3, Bennett Spring 2017 Texas Tech, Team S46-G3, Bennett Spring 2017 회원
TTU-BENNETT-S17S46G3
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 427
