주요 콘텐츠로 건너뛰기
HP Mini 210-2070NR RAM Replacement
필요한 것
  1. HP Mini 210-2070NR RAM Replacement, Battery and Service Access Cover: 1 단계, 이미지 1/1
    • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
  2. HP Mini 210-2070NR RAM Replacement: 2 단계, 이미지 1/3 HP Mini 210-2070NR RAM Replacement: 2 단계, 이미지 2/3 HP Mini 210-2070NR RAM Replacement: 2 단계, 이미지 3/3
    • The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
    • Slide the battery release latch inwards.
    • Pull the battery towards you to remove it.
  3. HP Mini 210-2070NR RAM Replacement: 3 단계, 이미지 1/3 HP Mini 210-2070NR RAM Replacement: 3 단계, 이미지 2/3 HP Mini 210-2070NR RAM Replacement: 3 단계, 이미지 3/3
    • Slide the service access cover release lever to the right.
    • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
  4. HP Mini 210-2070NR RAM Replacement: 4 단계, 이미지 1/1
    • Orient the computer as shown in the picture.
  5. HP Mini 210-2070NR RAM Replacement, RAM: 5 단계, 이미지 1/1
    • Using your fingers, pull the two white clips (tabs) on both sides of the RAM away from each other. Keep pulling the clips until the RAM pops up
    • Hold the RAM on the edges only. Touching the components on the RAM might damage it.
  6. HP Mini 210-2070NR RAM Replacement: 6 단계, 이미지 1/1
    • Grab the edges of the module and gently lift it from the slot.
    • RAM Cards are designed with a notch on the surface to prevent incorrect insertion into the memory module slot.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Sean Kuster
회원 가입일: 10/05/12
91 평판
안내서 3개 작성하였습니다
Cal Poly, Team 3-23, Amido Fall 2012 Cal Poly, Team 3-23, Amido Fall 2012 회원
CPSU-AMIDO-F12S3G23
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 2,060
