주요 콘텐츠로 건너뛰기
HP Mini 210-2070NR RTC Battery Replacement
필요한 것
  1. HP Mini 210-2070NR RTC Battery Replacement, Battery and Service Access Cover: 1 단계, 이미지 1/1
    • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
  2. HP Mini 210-2070NR RTC Battery Replacement: 2 단계, 이미지 1/3 HP Mini 210-2070NR RTC Battery Replacement: 2 단계, 이미지 2/3 HP Mini 210-2070NR RTC Battery Replacement: 2 단계, 이미지 3/3
    • The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
    • Slide the battery release latch inwards.
    • Pull the battery towards you to remove it.
  3. HP Mini 210-2070NR RTC Battery Replacement: 3 단계, 이미지 1/3 HP Mini 210-2070NR RTC Battery Replacement: 3 단계, 이미지 2/3 HP Mini 210-2070NR RTC Battery Replacement: 3 단계, 이미지 3/3
    • Slide the service access cover release lever to the right.
    • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
  4. HP Mini 210-2070NR RTC Battery Replacement: 4 단계, 이미지 1/1
    • Orient the computer as shown in the picture.
  5. HP Mini 210-2070NR RTC Battery Replacement, RTC Battery: 5 단계, 이미지 1/3 HP Mini 210-2070NR RTC Battery Replacement, RTC Battery: 5 단계, 이미지 2/3 HP Mini 210-2070NR RTC Battery Replacement, RTC Battery: 5 단계, 이미지 3/3
    • The RTC battery is a thin disk near the bottom left corner.
    • The black and red cable is the RTC battery cable.
    • Pull the RTC battery cable out of its socket.
  6. HP Mini 210-2070NR RTC Battery Replacement: 6 단계, 이미지 1/2 HP Mini 210-2070NR RTC Battery Replacement: 6 단계, 이미지 2/2
    • Gently pry the RTC battery upward with the plastic opening tool.
    • Remove RTC battery.
    • The RTC battery is attached with double sided tape.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Alek Linquist
회원 가입일: 10/05/12
123 평판
안내서 2개 작성하였습니다
Cal Poly, Team 3-23, Amido Fall 2012 Cal Poly, Team 3-23, Amido Fall 2012 회원
CPSU-AMIDO-F12S3G23
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 14
전체 시간: 1,263
