주요 콘텐츠로 건너뛰기
HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement
필요한 것
  1. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement, Battery and Service Access Cover: 1 단계, 이미지 1/1
    • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
  2. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 2 단계, 이미지 1/3 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 2 단계, 이미지 2/3 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 2 단계, 이미지 3/3
    • The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
    • Slide the battery release latch inwards.
    • Pull the battery towards you to remove it.
  3. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 3 단계, 이미지 1/3 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 3 단계, 이미지 2/3 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 3 단계, 이미지 3/3
    • Slide the service access cover release lever to the right.
    • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
  4. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 4 단계, 이미지 1/1
    • Orient the computer as shown in the picture.
  5. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement, Wi-Fi Card (WLAN Module): 5 단계, 이미지 1/2 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement, Wi-Fi Card (WLAN Module): 5 단계, 이미지 2/2
    • Locate the Wi-Fi Card (WLAN Module), near the computer's bottom left corner.
  6. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 6 단계, 이미지 1/3 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 6 단계, 이미지 2/3 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 6 단계, 이미지 3/3
    • Disconnect the two cables from the Wi-Fi card by gently lifting them away from the card.
    • There should be two black cables, one labeled with a white sticker, connected to the module.
  7. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 7 단계, 이미지 1/1
    • Remove the two 2.0 x 3.0 screws securing the Wi-Fi card using a Phillips #00 screwdriver
    • The card should tilt up away from the laptop at an angle after removing the screws.
  8. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 8 단계, 이미지 1/1
    • Remove the Wi-Fi card by gently pulling it out of its slot at an angle.
    • Potential for device damage: Be sure to pull gently and at an angle away from you. If the card is pulled straight up, there is a chance it could break or bend.
결론
Taylor
회원 가입일: 10/05/12
116 평판
안내서 1개 작성함
Cal Poly, Team 3-23, Amido Fall 2012 Cal Poly, Team 3-23, Amido Fall 2012 회원
CPSU-AMIDO-F12S3G23
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 1,181
