주요 콘텐츠로 건너뛰기
HP Mini 311 Hard Drive Replacement
필요한 것
  1. HP Mini 311 Hard Drive Replacement, Battery: 1 단계, 이미지 1/3 HP Mini 311 Hard Drive Replacement, Battery: 1 단계, 이미지 2/3 HP Mini 311 Hard Drive Replacement, Battery: 1 단계, 이미지 3/3
    • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
  2. HP Mini 311 Hard Drive Replacement: 2 단계, 이미지 1/2 HP Mini 311 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Slide the battery away from the device to remove.
  3. HP Mini 311 Hard Drive Replacement, Memory Shield: 3 단계, 이미지 1/1
    • With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
    • The screws will remain in the shied.
  4. HP Mini 311 Hard Drive Replacement: 4 단계, 이미지 1/2 HP Mini 311 Hard Drive Replacement: 4 단계, 이미지 2/2
    • Lift the memory shield up and remove from the laptop.
  5. HP Mini 311 Hard Drive Replacement, Hard Drive: 5 단계, 이미지 1/3 HP Mini 311 Hard Drive Replacement, Hard Drive: 5 단계, 이미지 2/3 HP Mini 311 Hard Drive Replacement, Hard Drive: 5 단계, 이미지 3/3
    • Grab the left black, plastic tab and carefully pull upward.
    • Be sure to pull carefully. Pulling too forcefully may damage the tab.
  6. HP Mini 311 Hard Drive Replacement: 6 단계, 이미지 1/3 HP Mini 311 Hard Drive Replacement: 6 단계, 이미지 2/3 HP Mini 311 Hard Drive Replacement: 6 단계, 이미지 3/3
    • Grab a hold of the wire connecting the hard drive and the device.
    • Pull upward, perpendicular to the surface of the laptop, releasing the connector tethering the hard drive to the motherboard.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Christian Santoyo
회원 가입일: 01/31/13
495 평판
안내서 6개 작성하였습니다
Cal Poly, Team 20-4, Maness Winter 2013 Cal Poly, Team 20-4, Maness Winter 2013 회원
CPSU-MANESS-W13S20G4
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
What size hard drive does this unit take?
Travis Duncan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 4,378
