소개
If you are having problems with internet connection, you may want to replace your wireless network card on your HP Mini 311.
필요한 것
Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
다른 2명이 해당 안내서를 완성하였습니다.
