주요 콘텐츠로 건너뛰기
HP Mobile Thin Client mt41 Back Cover Replacement
필요한 것
  1. HP Mobile Thin Client mt41 Back Cover Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the two slots on the bottom of the laptop to unlock the battery.
  2. HP Mobile Thin Client mt41 Back Cover Replacement: 2 단계, 이미지 1/2 HP Mobile Thin Client mt41 Back Cover Replacement: 2 단계, 이미지 2/2
    • Pull on both slots outwards as shown in the images to unlock the battery. The battery will not come out if the slots are locked. The battery should easily slide out without much force.
  3. HP Mobile Thin Client mt41 Back Cover Replacement, Back Cover: 3 단계, 이미지 1/2 HP Mobile Thin Client mt41 Back Cover Replacement, Back Cover: 3 단계, 이미지 2/2
    • Remove the nine screws that keep the back cover secured using the T5 Torx screwdriver.
  4. HP Mobile Thin Client mt41 Back Cover Replacement: 4 단계, 이미지 1/2 HP Mobile Thin Client mt41 Back Cover Replacement: 4 단계, 이미지 2/2
    • Remove the middle plate using the iFixit opening tool.
    • This may require a bit of force. If it is not coming out try the other side.
  5. HP Mobile Thin Client mt41 Back Cover Replacement: 5 단계, 이미지 1/1
    • Pop the back cover off from its latches by separating the two parts along their seam using the iFixit opening tool.
    • Be gentle; the plastic can crack.
  6. HP Mobile Thin Client mt41 Back Cover Replacement: 6 단계, 이미지 1/1
    • Lift the back cover once all corners are unclasped from their latches.
    • Lifting the cover should not require much force.
결론
Raul Rodriguez
회원 가입일: 02/27/18
289 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 17
전체 시간: 590
