주요 콘텐츠로 건너뛰기
HP Mobile Thin Client mt41 Fan Replacement
필요한 것
  1. HP Mobile Thin Client mt41 Fan Replacement, Back Cover: 1 단계, 이미지 1/2 HP Mobile Thin Client mt41 Fan Replacement, Back Cover: 1 단계, 이미지 2/2
    • Remove the nine screws that keep the back cover secured using the T5 Torx screwdriver.
  2. HP Mobile Thin Client mt41 Fan Replacement: 2 단계, 이미지 1/2 HP Mobile Thin Client mt41 Fan Replacement: 2 단계, 이미지 2/2
    • Remove the middle plate using the iFixit opening tool.
    • This may require a bit of force. If it is not coming out try the other side.
  3. HP Mobile Thin Client mt41 Fan Replacement: 3 단계, 이미지 1/1
    • Pop the back cover off from its latches by separating the two parts along their seam using the iFixit opening tool.
    • Be gentle; the plastic can crack.
  4. HP Mobile Thin Client mt41 Fan Replacement: 4 단계, 이미지 1/1
    • Lift the back cover once all corners are unclasped from their latches.
    • Lifting the cover should not require much force.
  5. HP Mobile Thin Client mt41 Fan Replacement, Fan: 5 단계, 이미지 1/2 HP Mobile Thin Client mt41 Fan Replacement, Fan: 5 단계, 이미지 2/2
    • Using a J1 head for your screwdriver, remove the 4 surrounding screws.
  6. HP Mobile Thin Client mt41 Fan Replacement: 6 단계, 이미지 1/1
    • Keep your screws close by, and slowly remove the CPU fan.
  7. HP Mobile Thin Client mt41 Fan Replacement: 7 단계, 이미지 1/1
    • Be mindful of wires, the final step is to unplug the fan from the motherboard, at the base of red and blue wires.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
William Rapp
회원 가입일: 02/08/18
171 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 17
전체 시간: 369
