주요 콘텐츠로 건너뛰기
HP Mobile Thin Client mt41 Optical Disc Drive Replacement
필요한 것
  1. HP Mobile Thin Client mt41 Optical Disc Drive Replacement, Optical Disc Drive: 1 단계, 이미지 1/2 HP Mobile Thin Client mt41 Optical Disc Drive Replacement, Optical Disc Drive: 1 단계, 이미지 2/2
    • Turn off and unplug your laptop. Also, make sure to disconnect all the external devices.
    • After that, slide the two switches to the indicated directions in order to remove the battery and the back cover.
  2. HP Mobile Thin Client mt41 Optical Disc Drive Replacement: 2 단계, 이미지 1/2 HP Mobile Thin Client mt41 Optical Disc Drive Replacement: 2 단계, 이미지 2/2
    • Now you're able to remove the battery and the service cover.
    • Slide the battery upward to remove it.
  3. HP Mobile Thin Client mt41 Optical Disc Drive Replacement: 3 단계, 이미지 1/3 HP Mobile Thin Client mt41 Optical Disc Drive Replacement: 3 단계, 이미지 2/3 HP Mobile Thin Client mt41 Optical Disc Drive Replacement: 3 단계, 이미지 3/3
    • Slide the service cover downward.
    • After that, lift the back cover to remove it.
  4. HP Mobile Thin Client mt41 Optical Disc Drive Replacement: 4 단계, 이미지 1/3 HP Mobile Thin Client mt41 Optical Disc Drive Replacement: 4 단계, 이미지 2/3 HP Mobile Thin Client mt41 Optical Disc Drive Replacement: 4 단계, 이미지 3/3
    • Unlock the indicated screw in order to remove the optical drive.
    • Slide the optical drive to completely remove it from the laptop.
결론
Hassan Almunasif
회원 가입일: 02/08/18
127 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 18
전체 시간: 442
