주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Notebook 15-ba018ds Wifi Chip Replacement
필요한 것
  1. HP Notebook 15-ba018ds Wifi Chip Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
    • Flip the laptop over so the battery is exposed which will be next to the hinges on the top left and right.
  2. HP Notebook 15-ba018ds Wifi Chip Replacement: 2 단계, 이미지 3개 중 1개 HP Notebook 15-ba018ds Wifi Chip Replacement: 2 단계, 이미지 3개 중 2개 HP Notebook 15-ba018ds Wifi Chip Replacement: 2 단계, 이미지 3개 중 3개
    • Place your thumbs on the slide locks that are next to the hinges and simultaneously push them toward each other to unlock the battery.
    • While still holding onto the slide locks, push the battery away from the laptop with your index fingers.
  3. HP Notebook 15-ba018ds Wifi Chip Replacement, Wifi Chip: 3 단계, 이미지 2개 중 1개 HP Notebook 15-ba018ds Wifi Chip Replacement, Wifi Chip: 3 단계, 이미지 2개 중 2개
    • Unscrew the 8 screws on the back cover.
    • There are also two screws in the battery area that need to be removed.
  4. HP Notebook 15-ba018ds Wifi Chip Replacement: 4 단계, 이미지 1개 중 1개
    • Use an opening tool to help remove the back cover.
    • If you look at the side of the laptop, you can see where it can be separated into two parts.
  5. HP Notebook 15-ba018ds Wifi Chip Replacement: 5 단계, 이미지 2개 중 1개 HP Notebook 15-ba018ds Wifi Chip Replacement: 5 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the screw holding down the wifi chip.
  6. HP Notebook 15-ba018ds Wifi Chip Replacement: 6 단계, 이미지 2개 중 1개 HP Notebook 15-ba018ds Wifi Chip Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the two wires connected to the wifi chip.
    • The wires are labeled 1 and 2. This is important to know when reconnecting the wires to the wifi chip.
    • Gently pull the wifi chip out and replace with a new wifi chip.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Terrell Bradford
회원 가입일: 09/18/18
443 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 31
전체 시간: 1,285
