주요 콘텐츠로 건너뛰기
HP Notebook 15-db003ca RAM Replacement
필요한 것
  1. HP Notebook 15-db003ca RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Place the powered-off laptop on a clean workspace.
  2. HP Notebook 15-db003ca RAM Replacement: 2 단계, 이미지 1/1
    • Flip the laptop over such that the backside of it is facing you.
    • Grab a Phillips #1 screwdriver.
  3. HP Notebook 15-db003ca RAM Replacement: 3 단계, 이미지 1/1
    • Remove the four 9 mm screws from the back panel using a Phillips #1 screwdriver.
  4. HP Notebook 15-db003ca RAM Replacement: 4 단계, 이미지 1/3 HP Notebook 15-db003ca RAM Replacement: 4 단계, 이미지 2/3 HP Notebook 15-db003ca RAM Replacement: 4 단계, 이미지 3/3
    • Peel the two strips to uncover more screws.
    • Place the strips near where they were removed.
  5. HP Notebook 15-db003ca RAM Replacement: 5 단계, 이미지 1/2 HP Notebook 15-db003ca RAM Replacement: 5 단계, 이미지 2/2
    • Remove the remaining seven 9 mm screws using a Phillips #1 screwdriver.
  6. HP Notebook 15-db003ca RAM Replacement: 6 단계, 이미지 1/3 HP Notebook 15-db003ca RAM Replacement: 6 단계, 이미지 2/3 HP Notebook 15-db003ca RAM Replacement: 6 단계, 이미지 3/3
    • Remove the back panel and locate the RAM stick.
  7. HP Notebook 15-db003ca RAM Replacement: 7 단계, 이미지 1/2 HP Notebook 15-db003ca RAM Replacement: 7 단계, 이미지 2/2
    • Push the RAM to remove it from its slot like shown in the picture.
    • When reassembling, ensure the memory is inserted into the slot and pushed until it clicks into place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Srivatsan Talkad
회원 가입일: 01/17/23
145 평판
안내서 1개 작성함
York University, Team M-9, Allen Summer 2023 York University, Team M-9, Allen Summer 2023 회원
YORK-ALLEN-SU23SMG9
2 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 24
전체 시간: 272
