주요 콘텐츠로 건너뛰기
HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement
필요한 것
  1. HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement, Manual One-Inch Paper-Feed Roller: 1 단계, 이미지 1/2 HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement, Manual One-Inch Paper-Feed Roller: 1 단계, 이미지 2/2
    • Open the document feeder cover by flipping it to the left with the front panel facing you.
    • The document feeder is designed to be a bit more difficult to open, so it is okay to use a little more force.
  2. HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement: 2 단계, 이미지 1/3 HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement: 2 단계, 이미지 2/3 HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement: 2 단계, 이미지 3/3
    • Locate the manual one-inch paper-feed roller end of the document feeder cover.
    • Remove the 11.0mm screw on the side of the roller with 2.0mm hex screwdriver.
  3. HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement: 3 단계, 이미지 1/3 HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement: 3 단계, 이미지 2/3 HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement: 3 단계, 이미지 3/3
    • Pull the side cover of the manual one-inch paper-feed roller to the right and remove the paper roller.
결론
Stephanie Carpintero
회원 가입일: 01/24/18
994 평판
안내서 5개 작성하였습니다
Cal Poly, Team S19-G6, Livingston Winter 2018 Cal Poly, Team S19-G6, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S19G6
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 22
전체 시간: 1,636
