주요 콘텐츠로 건너뛰기
HP OfficeJet 4650 Paper Tray Replacement
필요한 것
  1. HP OfficeJet 4650 Paper Tray Replacement, Paper Tray: 1 단계, 이미지 1/2 HP OfficeJet 4650 Paper Tray Replacement, Paper Tray: 1 단계, 이미지 2/2
    • Use two hands to carefully flip the printer upside down.
    • Remove the ten 14mm screws by using a 2.0 mm hex screwdriver and turning the screws counterclockwise.
  2. HP OfficeJet 4650 Paper Tray Replacement: 2 단계, 이미지 1/2 HP OfficeJet 4650 Paper Tray Replacement: 2 단계, 이미지 2/2
    • Lift the left and right side flaps away from the paper tray to remove them.
  3. HP OfficeJet 4650 Paper Tray Replacement: 3 단계, 이미지 1/3 HP OfficeJet 4650 Paper Tray Replacement: 3 단계, 이미지 2/3 HP OfficeJet 4650 Paper Tray Replacement: 3 단계, 이미지 3/3
    • Remove the left spring by grabbing the rubber tips connected to the spring and lifting up.
  4. HP OfficeJet 4650 Paper Tray Replacement: 4 단계, 이미지 1/2 HP OfficeJet 4650 Paper Tray Replacement: 4 단계, 이미지 2/2
    • Remove the right spring by grabbing the rubber tips connected to the spring and lifting up.
  5. HP OfficeJet 4650 Paper Tray Replacement: 5 단계, 이미지 1/1
    • Remove the paper tray by pulling the tray away from the printer.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Stephanie Carpintero
회원 가입일: 01/24/18
994 평판
안내서 5개 작성하였습니다
Cal Poly, Team S19-G6, Livingston Winter 2018 Cal Poly, Team S19-G6, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S19G6
3 회원들
안내서 10개 작성하였습니다
댓글 3개
Thank you Stephanie from a clumsy nearly 80yr old who had pulled the tray right out! A very clear guide to a simple job I had not got a clue how to do. Stay virus free and prosper. JG (UK)
John G - 답글
Any ideas where a aperson could order a replacement paper tray like this one? (For an HP OfficeJet 4650 model?
suemouthey - 답글
I broke the back of the paper tray so my printer continually says to add paper. Where can I buy another paper tray without having to buy a brand new printer?
Jacquie - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 36
전체 시간: 4,648
