소개
The paper tray is what feeds paper to the printer. If the paper tray is malfunctioning, the HP OfficeJet 4650's printing function will not work. This guide will show you how to replace the paper tray.
필요한 것
Use two hands to carefully flip the printer upside down.
Remove the ten 14mm screws by using a 2.0 mm hex screwdriver and turning the screws counterclockwise.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 3개
Any ideas where a aperson could order a replacement paper tray like this one? (For an HP OfficeJet 4650 model?
suemouthey - 답글
