주요 콘텐츠로 건너뛰기
HP Officejet 4630 Fax Feeder Replacement
필요한 것
  1. HP Officejet 4630 Fax Feeder Replacement, Fax Feeder: 1 단계, 이미지 1/2 HP Officejet 4630 Fax Feeder Replacement, Fax Feeder: 1 단계, 이미지 2/2
    • Lift the fax feeder cover until it stands on its own.
  2. HP Officejet 4630 Fax Feeder Replacement: 2 단계, 이미지 1/3 HP Officejet 4630 Fax Feeder Replacement: 2 단계, 이미지 2/3 HP Officejet 4630 Fax Feeder Replacement: 2 단계, 이미지 3/3
    • Use the plastic opening tool to unclasp the hinge that holds the feeder cover.
  3. HP Officejet 4630 Fax Feeder Replacement: 3 단계, 이미지 1/2 HP Officejet 4630 Fax Feeder Replacement: 3 단계, 이미지 2/2
    • Lift the green tab to remove the fax feeder from the printer.
  4. HP Officejet 4630 Fax Feeder Replacement: 4 단계, 이미지 1/3 HP Officejet 4630 Fax Feeder Replacement: 4 단계, 이미지 2/3 HP Officejet 4630 Fax Feeder Replacement: 4 단계, 이미지 3/3
    • Use the plastic opening tool to pry the pivot point apart while lifting the feeder up.
    • There is still a cable holding the part to the rest of the printer.
  5. HP Officejet 4630 Fax Feeder Replacement: 5 단계, 이미지 1/2 HP Officejet 4630 Fax Feeder Replacement: 5 단계, 이미지 2/2
    • Use a screwdriver to remove the single 9mm T10 screw.
    • Remove the wire cover and pull the wire away from the printer. The fax feeder head is now free to be separated from the printer.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Isaac Jacobsen
회원 가입일: 01/23/18
585 평판
안내서 1개 작성함
Cal Poly, Team S18-G3, Livingston Winter 2018 Cal Poly, Team S18-G3, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S18G3
4 회원들
안내서 18개 작성하였습니다
댓글 한 개
I am so glad i found this site…I was able to unjam a lease that had gotten stuck…..thank you thank you7… times over…Lee
Lee Shankle - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 1,078
