주요 콘텐츠로 건너뛰기
HP Officejet 4630 LCD Display Replacement
필요한 것
  1. HP Officejet 4630 LCD Display Replacement, LCD Display: 1 단계, 이미지 1/3 HP Officejet 4630 LCD Display Replacement, LCD Display: 1 단계, 이미지 2/3 HP Officejet 4630 LCD Display Replacement, LCD Display: 1 단계, 이미지 3/3
    • There is a hidden screw underneath the model sticker on the front panel.
    • Peel the model sticker off the cover.
    • This will expose the T10 screw securing the panel.
  2. HP Officejet 4630 LCD Display Replacement: 2 단계, 이미지 1/3 HP Officejet 4630 LCD Display Replacement: 2 단계, 이미지 2/3 HP Officejet 4630 LCD Display Replacement: 2 단계, 이미지 3/3
    • Remove the single 12mm-T10 screw securing the front panel to the printer body.
    • Loosen the panel cover from the printer body.
    • There is a ribbon cable connected to the backside of the cover. Disconnect the cable before separating the panel completely.
  3. HP Officejet 4630 LCD Display Replacement: 3 단계, 이미지 1/3 HP Officejet 4630 LCD Display Replacement: 3 단계, 이미지 2/3 HP Officejet 4630 LCD Display Replacement: 3 단계, 이미지 3/3
    • Gently remove the No-Fuss ribbon cable from the front panel.
  4. HP Officejet 4630 LCD Display Replacement: 4 단계, 이미지 1/3 HP Officejet 4630 LCD Display Replacement: 4 단계, 이미지 2/3 HP Officejet 4630 LCD Display Replacement: 4 단계, 이미지 3/3
    • Remove the seven 8mm screws using the Torx T6 screwdriver.
    • Remove the motherboard from the front-panel housing.
    • The LCD display is on the opposite side.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Justin Engwall
회원 가입일: 01/23/18
137 평판
안내서 1개 작성함
Cal Poly, Team S18-G3, Livingston Winter 2018 Cal Poly, Team S18-G3, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S18G3
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 11
전체 시간: 1,543
