주요 콘텐츠로 건너뛰기
HP Officejet 4630 Paper Tray Replacement
필요한 것
  1. HP Officejet 4630 Paper Tray Replacement, Paper Tray: 1 단계, 이미지 1/1
    • Begin by turning your printer upside down.
    • It can be helpful to position an object beneath the printer to keep it level while you work on it.
  2. HP Officejet 4630 Paper Tray Replacement: 2 단계, 이미지 1/1
    • Use the T-10 screwdriver to remove the two 11-mm screws.
  3. HP Officejet 4630 Paper Tray Replacement: 3 단계, 이미지 1/1
    • Pull the paper tray out until it hits the stops on either side of the tray.
  4. HP Officejet 4630 Paper Tray Replacement: 4 단계, 이미지 1/3 HP Officejet 4630 Paper Tray Replacement: 4 단계, 이미지 2/3 HP Officejet 4630 Paper Tray Replacement: 4 단계, 이미지 3/3
    • Lift up on one side of the black plastic bar with one hand while pulling the paper tray out of the printer with your other hand.
    • The side of the tray should slide away from the printer a little bit.
  5. HP Officejet 4630 Paper Tray Replacement: 5 단계, 이미지 1/2 HP Officejet 4630 Paper Tray Replacement: 5 단계, 이미지 2/2
    • Repeat the previous step but for the other side of the tray.
  6. HP Officejet 4630 Paper Tray Replacement: 6 단계, 이미지 1/1
    • The paper tray should now be free to slide away from the printer.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Tyler Allen
회원 가입일: 01/24/18
477 평판
안내서 2개 작성하였습니다
Cal Poly, Team S18-G3, Livingston Winter 2018 Cal Poly, Team S18-G3, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S18G3
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 1,828
