주요 콘텐츠로 건너뛰기
HP Officejet 4630 Scanner Head Replacement
필요한 것
  1. HP Officejet 4630 Scanner Head Replacement, LCD Display: 1 단계, 이미지 1/3 HP Officejet 4630 Scanner Head Replacement, LCD Display: 1 단계, 이미지 2/3 HP Officejet 4630 Scanner Head Replacement, LCD Display: 1 단계, 이미지 3/3
    • There is a hidden screw underneath the model sticker on the front panel.
    • Peel the model sticker off the cover.
    • This will expose the T10 screw securing the panel.
  2. HP Officejet 4630 Scanner Head Replacement: 2 단계, 이미지 1/3 HP Officejet 4630 Scanner Head Replacement: 2 단계, 이미지 2/3 HP Officejet 4630 Scanner Head Replacement: 2 단계, 이미지 3/3
    • Remove the single 12mm-T10 screw securing the front panel to the printer body.
    • Loosen the panel cover from the printer body.
    • There is a ribbon cable connected to the backside of the cover. Disconnect the cable before separating the panel completely.
  3. HP Officejet 4630 Scanner Head Replacement: 3 단계, 이미지 1/3 HP Officejet 4630 Scanner Head Replacement: 3 단계, 이미지 2/3 HP Officejet 4630 Scanner Head Replacement: 3 단계, 이미지 3/3
    • Gently remove the No-Fuss ribbon cable from the front panel.
  4. HP Officejet 4630 Scanner Head Replacement: 4 단계, 이미지 1/3 HP Officejet 4630 Scanner Head Replacement: 4 단계, 이미지 2/3 HP Officejet 4630 Scanner Head Replacement: 4 단계, 이미지 3/3
    • Remove the seven 8mm screws using the Torx T6 screwdriver.
    • Remove the motherboard from the front-panel housing.
    • The LCD display is on the opposite side.
  5. HP Officejet 4630 Scanner Head Replacement, Power Supply: 5 단계, 이미지 1/3 HP Officejet 4630 Scanner Head Replacement, Power Supply: 5 단계, 이미지 2/3 HP Officejet 4630 Scanner Head Replacement, Power Supply: 5 단계, 이미지 3/3
    • Lift the hood of the printer.
  6. HP Officejet 4630 Scanner Head Replacement: 6 단계, 이미지 1/3 HP Officejet 4630 Scanner Head Replacement: 6 단계, 이미지 2/3 HP Officejet 4630 Scanner Head Replacement: 6 단계, 이미지 3/3
    • Remove the two T10 11mm screws.
  7. HP Officejet 4630 Scanner Head Replacement: 7 단계, 이미지 1/3 HP Officejet 4630 Scanner Head Replacement: 7 단계, 이미지 2/3 HP Officejet 4630 Scanner Head Replacement: 7 단계, 이미지 3/3
    • Remove the panels covering the power brick and cord.
  8. HP Officejet 4630 Scanner Head Replacement: 8 단계, 이미지 1/2 HP Officejet 4630 Scanner Head Replacement: 8 단계, 이미지 2/2
    • Remove the cord from the power supply.
  9. HP Officejet 4630 Scanner Head Replacement: 9 단계, 이미지 1/3 HP Officejet 4630 Scanner Head Replacement: 9 단계, 이미지 2/3 HP Officejet 4630 Scanner Head Replacement: 9 단계, 이미지 3/3
    • Slide the power supply out from the chassis.
    • The power supply is still attached; don't pull too quickly.
  10. HP Officejet 4630 Scanner Head Replacement: 10 단계, 이미지 1/1
    • Remove final cable from power supply.
  11. HP Officejet 4630 Scanner Head Replacement, Scanner Head: 11 단계, 이미지 1/1
    • Remove eight T10 1mm screws from the top hood of the printer.
  12. HP Officejet 4630 Scanner Head Replacement: 12 단계, 이미지 1/3 HP Officejet 4630 Scanner Head Replacement: 12 단계, 이미지 2/3 HP Officejet 4630 Scanner Head Replacement: 12 단계, 이미지 3/3
    • Use the nylon spudger to pry the tab.
    • Lift up the entire panel.
  13. HP Officejet 4630 Scanner Head Replacement: 13 단계, 이미지 1/3 HP Officejet 4630 Scanner Head Replacement: 13 단계, 이미지 2/3 HP Officejet 4630 Scanner Head Replacement: 13 단계, 이미지 3/3
    • Lift and flip the entire panel.
    • Be aware of the scanner head attached to the panel.
  14. HP Officejet 4630 Scanner Head Replacement: 14 단계, 이미지 1/3 HP Officejet 4630 Scanner Head Replacement: 14 단계, 이미지 2/3 HP Officejet 4630 Scanner Head Replacement: 14 단계, 이미지 3/3
    • Start with the scanner head in place.
    • Unwind the ribbon from the track.
    • Detach ribbon completely.
결론
Maya Willis
회원 가입일: 01/24/18
415 평판
안내서 3개 작성하였습니다
Cal Poly, Team S18-G3, Livingston Winter 2018 Cal Poly, Team S18-G3, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S18G3
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 22
전체 시간: 1,446
