주요 콘텐츠로 건너뛰기
HP Officejet 4630 Speaker Replacement
필요한 것
  1. HP Officejet 4630 Speaker Replacement, Power Supply: 1 단계, 이미지 1/3 HP Officejet 4630 Speaker Replacement, Power Supply: 1 단계, 이미지 2/3 HP Officejet 4630 Speaker Replacement, Power Supply: 1 단계, 이미지 3/3
    • Lift the hood of the printer.
  2. HP Officejet 4630 Speaker Replacement: 2 단계, 이미지 1/3 HP Officejet 4630 Speaker Replacement: 2 단계, 이미지 2/3 HP Officejet 4630 Speaker Replacement: 2 단계, 이미지 3/3
    • Remove the two T10 11mm screws.
  3. HP Officejet 4630 Speaker Replacement: 3 단계, 이미지 1/3 HP Officejet 4630 Speaker Replacement: 3 단계, 이미지 2/3 HP Officejet 4630 Speaker Replacement: 3 단계, 이미지 3/3
    • Remove the panels covering the power brick and cord.
  4. HP Officejet 4630 Speaker Replacement: 4 단계, 이미지 1/2 HP Officejet 4630 Speaker Replacement: 4 단계, 이미지 2/2
    • Remove the cord from the power supply.
  5. HP Officejet 4630 Speaker Replacement: 5 단계, 이미지 1/3 HP Officejet 4630 Speaker Replacement: 5 단계, 이미지 2/3 HP Officejet 4630 Speaker Replacement: 5 단계, 이미지 3/3
    • Slide the power supply out from the chassis.
    • The power supply is still attached; don't pull too quickly.
  6. HP Officejet 4630 Speaker Replacement: 6 단계, 이미지 1/1
    • Remove final cable from power supply.
  7. HP Officejet 4630 Speaker Replacement, LCD Display: 7 단계, 이미지 1/3 HP Officejet 4630 Speaker Replacement, LCD Display: 7 단계, 이미지 2/3 HP Officejet 4630 Speaker Replacement, LCD Display: 7 단계, 이미지 3/3
    • There is a hidden screw underneath the model sticker on the front panel.
    • Peel the model sticker off the cover.
    • This will expose the T10 screw securing the panel.
  8. HP Officejet 4630 Speaker Replacement: 8 단계, 이미지 1/3 HP Officejet 4630 Speaker Replacement: 8 단계, 이미지 2/3 HP Officejet 4630 Speaker Replacement: 8 단계, 이미지 3/3
    • Remove the single 12mm-T10 screw securing the front panel to the printer body.
    • Loosen the panel cover from the printer body.
    • There is a ribbon cable connected to the backside of the cover. Disconnect the cable before separating the panel completely.
  9. HP Officejet 4630 Speaker Replacement: 9 단계, 이미지 1/3 HP Officejet 4630 Speaker Replacement: 9 단계, 이미지 2/3 HP Officejet 4630 Speaker Replacement: 9 단계, 이미지 3/3
    • Gently remove the No-Fuss ribbon cable from the front panel.
  10. HP Officejet 4630 Speaker Replacement: 10 단계, 이미지 1/3 HP Officejet 4630 Speaker Replacement: 10 단계, 이미지 2/3 HP Officejet 4630 Speaker Replacement: 10 단계, 이미지 3/3
    • Remove the seven 8mm screws using the Torx T6 screwdriver.
    • Remove the motherboard from the front-panel housing.
    • The LCD display is on the opposite side.
  11. HP Officejet 4630 Speaker Replacement, Speaker: 11 단계, 이미지 1/2 HP Officejet 4630 Speaker Replacement, Speaker: 11 단계, 이미지 2/2
    • Remove the clip that keeps the printer lid from opening all the way with your hands by pulling away from the post on the lid.
  12. HP Officejet 4630 Speaker Replacement: 12 단계, 이미지 1/3 HP Officejet 4630 Speaker Replacement: 12 단계, 이미지 2/3 HP Officejet 4630 Speaker Replacement: 12 단계, 이미지 3/3
    • Remove the paper feed rollers by using your fingers to pinch the indentations together while pulling up.
  13. HP Officejet 4630 Speaker Replacement: 13 단계, 이미지 1/2 HP Officejet 4630 Speaker Replacement: 13 단계, 이미지 2/2
    • Remove the ten 11mm-T10 screws with the screwdriver.
    • The top half of the printer might fall open as you remove the screws closer to the hinges.
  14. HP Officejet 4630 Speaker Replacement: 14 단계, 이미지 1/3 HP Officejet 4630 Speaker Replacement: 14 단계, 이미지 2/3 HP Officejet 4630 Speaker Replacement: 14 단계, 이미지 3/3
    • Push the clip holding the speaker in away from the speaker while pulling up on the speaker.
    • At this point you must cut and solder on your new speaker.
결론
Tyler Allen
회원 가입일: 01/24/18
477 평판
안내서 2개 작성하였습니다
Cal Poly, Team S18-G3, Livingston Winter 2018 Cal Poly, Team S18-G3, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S18G3
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 23
전체 시간: 950
