주요 콘텐츠로 건너뛰기
HP Officejet J3680 Motherboard Replacement
필요한 것
  1. HP Officejet J3680 Motherboard Replacement, Unplug the Device: 1 단계, 이미지 1/1
    • Remove the plug from the outlet and from the back of the device
    • Remove the USB Cable from your computer and from the back of the device.
  2. HP Officejet J3680 Motherboard Replacement, Remove Screws From Under the Control Panel: 2 단계, 이미지 1/1
    • Using your Torx T10 screwdriver, remove the screws indicated in the picture. Screws are 13mm in length.
  3. HP Officejet J3680 Motherboard Replacement, Remove Screws Underneath the Ink Cartridge Cover: 3 단계, 이미지 1/1
  4. HP Officejet J3680 Motherboard Replacement, Remove Screws from Underneath the Phone Panel: 4 단계, 이미지 1/1
    • In step 2, you removed the screw from the blue indicated area.
    • Gently pop off the black cover that the phone rests on. Underneath this cover, you will find two more screws.
  5. HP Officejet J3680 Motherboard Replacement, Remove the Screws from the Rear of Device: 5 단계, 이미지 1/1
  6. HP Officejet J3680 Motherboard Replacement, Remove Rear Plastic Panel: 6 단계, 이미지 1/1
    • Once the rear plastic panel has been removed, you are ready to replace and repair the necessary parts.
  7. HP Officejet J3680 Motherboard Replacement, Remove Plugs from Main Motherboard: 7 단계, 이미지 1/1
    • Carefully unplug all of the plugs that are connected to the main motherboard indicating in the picture.
  8. HP Officejet J3680 Motherboard Replacement, Remove Screws: 8 단계, 이미지 1/1
    • Using your Torx t10 screwdriver, remove the 4 screws that hold the main motherboard to the device. Screws are 13mm in length.
    • Once removed, the main motherboard will be free from the device. You will notice that on the lefthand side, three of the screws hold down green wires. Make sure when replacing the motherboard that you screw these back into place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Evan
회원 가입일: 10/20/14
361 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 1-1, Duarte Fall 2014 UMass Dartmouth, Team 1-1, Duarte Fall 2014 회원
UMASSD-DUARTE-F14S1G1
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 430
